can't call out with sipgate, was: dumping my sip provider
May 14, 2009 5 Replies
Jump to replies (5)
cisco router 2651XM IOS: c2600-adventerprisek9-mz.124-15.T8.bin
I have a sip trunk running on my above router that worked ok when registering with tescointernetphone.com, but following advice I had in uk.telecom.voip I decided to give sipgate1000 a go. In the router config I've changed the sip registration to sipgate.co.uk and the sip trunk registers fine to sipgate but I can't make outgoing calls, I get the engaged signal all the time, even if I dial voicemail (50000). But I can get incoming calls. I know it's a problem with my router config because if I use xlite on my pc registered to sipgate.co.uk I can dial voicemail without any problem.
My running config contains this:
dial-peer voice 2 voip description **Outgoing Call to SIP Trunk** translation-profile outgoing PSTN_Outgoing destination-pattern .T voice-class codec 1 session protocol sipv2 session target sip-server dtmf-relay rtp-nte no vad
and it worked fine with tescointernetphone, but maybe the settings should be different for sipgate, I don't know. Any ideas? tia.
debug?
debug dial-peer ? debug ccsip ?
I forget the dertails and do not have a voice router handy but there are extensive debugs available. Might be obvious what is amiss.
I've got a sneeking recollection that its Sipgate.net isn't it? But I'm probably wrong.
Try dialling their automated test number - 10000 - which will answer you in German but at least show if it is working or not.
It's in English, or at least an attempt!
Well that indicates they are thinking of their customers now! It was German last time I tried - probably late 2007.
