no audio on voicemail number
May 19, 2009 13 Replies
Jump to replies (13)
no audio on voicemail number open original image
cisco 2651XM router IOS: c2600-adventerprisek9-mz.124-15.T8.bin sip trunk working and registered to sipgate.co.uk
7940G ip phone
I have a problem with my ip phone connection in that I can't get any audio when calling my voicemail number, yet all other numbers work fine. sipgate voixemail is 50000 from my sipgate phone, or 02070437777 from a different line. If I dial 50000 from the sipgate phone the display shows 'Connected' but there's no audio. If I also dial 02070437777 from my sipgate phone I get the same - connection but just silence. What's strange is if I call the voicemail number 02070437777 number from a different phone I hear audio so the problem has to be with my router. I've forwarded the port in the router, that didn't solve it. I know I need to run a debug on this but my question is: which debug should I run? I tried debug ccsip messages but I couldn't see anything in the log relevant to this problem. I also ran debug dialpeer, same result. I also ran debug voice call trap fsm but I couldn't see anything. I know the problem is in the router config because if I use xlite on my pc I can get audio on the voicemail no problem. thanks for any pointers.
Does the 10000 test number work? Ivor's speaking clock on 020 7043 1320 is another Sipgate number you could try.
thanks for your response, yes both 10000 and 020 7043 1320 work fine, I can hear audio when I ring them.
Bit of a tough one to narrow down. Seems a bit odd that 10000 works but
50000 doesn't. If the debug output doesn't show anything of any interest, then I would take a packet capture of each call and compare the differences.
Are you seeing anything from 217.10.79.35 being dropped, perchance? I compared calls to each number, RTP comes from 217.10.79.30 when using the test number and 217.10.79.35 when dialling voicemail.
ok thanks but which debug do you think I should run to catch the info you speak of?
What is the problem?
Barry ===== Home page
The notion that faith in Christ is to be rewarded by an eternity of bliss, while a dependence upon reason, observation, and experience merits everlasting pain, is too absurd for refutation, and can be relieved only by that unhappy mixture of insanity and ignorance called 'faith.' [Robert Green Ingersoll]
ps: here is a small section of my config which shows the settings I have for voicemail with sipgate.co.uk. Does anything look wrong to you?
voice class codec 1 codec preference 1 g711ulaw
dial-peer voice 3 voip description **voicemail** destination-pattern 50000 voice-class codec 1 voice-class sip dtmf-relay force rtp-nte session protocol sipv2 session target sip-server dtmf-relay rtp-nte no vad
seems to me there must be a wrong setting in there somewhere....
in fact here's the whole router config is interested:
I meant check ACL logging in case RTP is being dropped unexpectedly, although you'd think having the SIP UA running on the edge would eliminate this kind of nonsense...
My only experience with Cisco voice kit is having a UC500 demo kit for a few weeks and using a 7941G with Asterisk. A quick google came up with this:
There are several interesting looking debug commands, but you'll have to get someone else to interpret the output :-) If the debug output is no use, there's always packet capture.
I did the packet trace thing and the data is streaming in 'as though' the phone is receiving audio. I compared the packet stream with a call containing audio to a call (to voicemail) containing silence and they were practically identical. Even though I couldn't hear anything on the voicemail number the data was pouring into the phone so it's a case of the phone (or the router) can't turn it back into audio. There must be something about the voicemail stream that is different to a normal PSTN call. This made me think of codec but I've tested every codec available in the dial peer and nothing will bring on the audio. It's so wierd.
anyway it looks as as though I might have to throw in the towel on this. As a final test I bought some credit with draytel.org and gave them a try. I used exactly the same settings on my equipment as I did with sipgate and whaddya know...their voicemail worked perfectly first time. The voicemail of both draytel and tescointernetphone work fine on my setup but sipgate doesn't. There has got to be something wrong or slightly different about sipgate the voicemail system but multiple emails to sipgate support have drawn a blank.
If you open up a packet capture in wireshark, you'll be able to play the captured audio stream back [if it's SIP/RTP, not sure about SCCP]. One thing I noticed with the voicemail call, the call setup packets coming from Sipgate didn't specify a packetisation time ['ptime']. May or may not be significant.
The only difference I've been able to discern is what peer the RTP goes to/from, and the lack of a ptime in the SDP part of the call.
This looks useful:
The debug output I got from Asterisk when calling Sipgate voicemail and other numbers indicated the accepted range of codecs were identical. Also the call setup would fail if the codecs don't overlap - an essential feature of SIP.
Sipgate support is pretty much non-existent, and such support that does exist will be unlikely to include Call Manager. I'm not knocking Sipgate however; the service is excellent for the price!
