Need help with PIX commands
Sep 15, 2006 2 Replies
I did a 'sh running config' command and I see that I have: isakmp identity address
I imagine my VPN issues may clear up if I change it to 'isakmp identity hostname'
Should I do: no isakmp identity address isakmp identity hostname wr mem reload
That's all I need to change, right?
Thanks!
Your commands are ok but i am quit sure the reboot is not needed for that, and you don't have to do the "no" line.
So the following would be enough ;
but feel free to reload if you want to be sure
Thank you! I will try it this weekend!
mcaissie wrote:
