PIX 501 - VPN connection question
Feb 28, 2006 1 Replies
My company is using two PIX 501 and establish the VPN connection between two office. Now one of office is changed to use the other ISP and of course the fixed IP is changed also. Would anyone tell me how can I change the configuration to make the VPN connection work?
Thanks a lot.
show conf | grep isakmp
will give you the PSK for a site IP which does not exist anymore, let say the IP is aaa.bbb.ccc.ddd
show conf | grep aaa.bbb.ccc.ddd
should give you this unused IP bound to a crypto map you have to update.
So, on the remoe site having the new IP, change the IP. Unless you remember the PSK, you may need to change it to match the PSK you got, like, for both sites.
wri mem
clear crypto ipsec sa debug crypto isak debug crrypto ipsec
sh crypto isak sa det
Good luck,
Alfred
Michael Wai wrote:
