Cisco VPN using BT HUB Router
Sep 15, 2006 0 Replies
I have found that I can connect fine using Cisco VPN client to work on my newly acquired BT Hub router. Unfortunately, I find that I get disconnected even if in the middle of working rather than leaving alone for any period of time.
BT are no use what so ever as they just say they have no expertise with Cisco VPN software. I have proved by using my laptop on other broadband routers that it works fine and does not disconnect. I also am connected through Ethernet so I can rule out any wireless issues.
The only way I have found to keep it alive for any great period of time is to set a ping -t running. This definitely helps, but eventully it will go.
Any ideas or does anyone have this working?
My network guys at works are stumped so any help would be appreciated.
Cheers, Chris.
