Quick help needed: Adding IP scope passthrough on cisco 828
Jun 14, 2006 8 Replies
Jump to replies (8)
I have a cisco 828 router which is passing all traffic into our firewall.
sh running gives me this (among other):
ip nat inside source list 2 interface BVI1 overload ip classless ip route 0.0.0.0 0.0.0.0 z.x.c.v ip route a.b.c.d 255.255.255.248 10.10.10.5 ip http server
The "problem" is that now we get a new set of IP addresses (because of more IP's needed)
How do I edit the above to pass all trafic from ip q.w.e.r subnet 255.255.255.240 to IP 10.10.10.5 instead of ip route a.b.c.d 255.255.255.248 10.10.10.5 ?
Regards, Lars.
conf t no ip route a.b.c.d 255.255.255.248 10.10.10.5 ip route q.w.e.r 255.255.255.240 10.10.10.5 exit
wri mem
sh ip route static
"Merv" skrev i en meddelelse news: snipped-for-privacy@u72g2000cwu.googlegroups.com...
What does conf t mean? you thing config?
that simple?
Or copy runnning-config startup-config ?
Lars Bonnesen skrev:
typing the following in the config mode should do the trick:
ip route q.w.e.r 255.255.255.240 10.10.10.5 no ip route a.b.c.d 255.255.255.248 10.10.10.5
Also please note the NAT access list, you may need to change that as well to provide NATing for the new addresses.
-SAto
that is the command used to enter configuration mode (actually an abbreviation of "configure terminal").
Yes
Yes
-SAto
"SAto" skrev i en meddelelse news: snipped-for-privacy@y41g2000cwy.googlegroups.com...
The only thing regarding this is:
ip address 10.10.10.1 255.255.255.0 ip nat inside
interface BVI1 ip address a.b.c.d 255.255.255.252 ip nat outside
access-list 2 permit 10.10.10.0 0.0.0.255 access-list 23 permit 10.10.10.0 0.0.0.255
Nothing more regaring NAT.
But I have tried (as a test) to add y.y.y.y 255.255.255.255 10.10.10.5 (without saveing and restarting), and it does not show up in the sh ip route or sh config. Do I need to save and reboot it in order to have it here?
Regards, Lars.
"Lars Bonnesen" skrev i en meddelelse news:44900dec$0$139$ snipped-for-privacy@dread11.news.tele.dk...
Ok, now I get it - config terminal... (-;
Regards, Lars.
As long as the new network you are adding does not need to be NATed you should be good. This access list will allow only addresses in the
10.10.10.1-254 range to be NATed.
No, there should be no need to either save nor reboot. are you sure the command is entered correctly?
conf t ip route y.y.y.y 255.255.255.255 10.10.10.5
the mask you supply above is a host mask, probably not what you want for that network but it should display in the routing table and the "sh running" command.
The "sh config" command only displays configuration that is saved with the wr mem or copy run start commands.
-SAto
It is working as expected and very nicely. Thanks to all of you.,
Regards, Lars.
