PIX VPN Help
Aug 18, 2006 1 Replies
I am in the process of setting up a vpn on my PIX 515E running IOS
7.04, but ran into a bit of a snag. I am able to connect to the vpn and grab an ip address from the ip pool I setup, but I am unable to communicate with the network on the inside of the pix. I have started over from scratch just to be on the safe side, but can any one help me out?
63.x.x.200 "Outside"
172.16.1.0/24 "Inside"
172.16.2.0/24 "VPN Pool"
# sh run : Saved : PIX Version 7.0(4) ! hostname pix0-bw domain-name domain.com enable password XXXXXXXXXXXXXX encrypted names ! interface Ethernet0 nameif outside security-level 0 ip address 63.x.x.200 255.255.255.0 ! interface Ethernet1 nameif inside security-level 100 ip address 172.16.1.1 255.255.255.0 ! passwd XXXXXXXXXXXXXXX encrypted ftp mode passive access-list 101 extended permit ip 172.16.1.0 255.255.255.0 172.16.2.0
255.255.255.0 pager lines 24 mtu outside 1500 mtu inside 1500 ip local pool bigpool 172.16.2.1-172.16.2.254 no asdm history enable arp timeout 14400 global (outside) 1 interface nat (inside) 0 access-list 101 nat (inside) 1 0.0.0.0 0.0.0.0 route outside 0.0.0.0 0.0.0.0 63.x.x.1 1 timeout xlate 3:00:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02 timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 timeout mgcp-pat 0:05:00 sip 0:30:00 sip_media 0:02:00 timeout uauth 0:05:00 absolute group-policy vpn3000-all internal group-policy vpn3000-all attributes wins-server value 172.16.1.10 dns-server value 172.16.1.11 vpn-idle-timeout 30 default-domain value domain.com username jtrooney password XXXXXXXXXXXXXXX encrypted no snmp-server location no snmp-server contact snmp-server enable traps snmp authentication linkup linkdown coldstart crypto ipsec transform-set myset esp-des esp-md5-hmac crypto dynamic-map dynmap 10 set transform-set myset crypto map mymap 10 ipsec-isakmp dynamic dynmap crypto map mymap interface outside isakmp identity address isakmp enable outside isakmp policy 10 authentication pre-share isakmp policy 10 encryption des isakmp policy 10 hash md5 isakmp policy 10 group 1 isakmp policy 10 lifetime 86400 isakmp policy 20 authentication pre-share isakmp policy 20 encryption des isakmp policy 20 hash md5 isakmp policy 20 group 2 isakmp policy 20 lifetime 86400 tunnel-group DefaultRAGroup general-attributes address-pool (outside) bigpool tunnel-group DefaultRAGroup ipsec-attributes pre-shared-key * tunnel-group vpn3000-all type ipsec-ra tunnel-group vpn3000-all general-attributes address-pool bigpool default-group-policy vpn3000-all tunnel-group vpn3000-all ipsec-attributes pre-shared-key * telnet 0.0.0.0 0.0.0.0 outside telnet 0.0.0.0 0.0.0.0 inside telnet timeout 5 ssh 63.x.x.0 255.255.255.0 outside ssh 0.0.0.0 0.0.0.0 inside ssh timeout 60 console timeout 0 ! class-map inspection_default match default-inspection-traffic ! ! policy-map global_policy class inspection_default inspect dns maximum-length 512 inspect ftp inspect h323 h225 inspect h323 ras inspect netbios inspect rsh inspect rtsp inspect skinny inspect esmtp inspect sqlnet inspect sunrpc inspect tftp inspect sip inspect xdmcp ! service-policy global_policy global Cryptochecksum:b04d6c8fd2df389367aa283874d7be63 : end
