LAYER 3 SWITCH BCMSN EXAM
Dec 12, 2006 2 Replies
Is it necessary to have a Layer 3 switch to study for the new BCMSN exam for the CCNP, or can I just use Layer 2 switches?
Thanks
----------------------- if you will test lab BCMSN you will have
  1. router (1 or more FastEthernet, model 2600 or later)
  2. L2 Switch (2950, 2960)
So with Layer 2 switches as the ones you mentioned should be fine for the new BCMSN 642-812 exam? A Layer 3 switch would not be necessary?
Thank you for the reply.
