installing SDM on an 877 DSL router ... having RCP problems ...
Mar 08, 2006 0 Replies
I have a Cisco 877 router which only has the IOS file installed in flash. I'm wanting to install SDM so I can use this to do the basic configuration. When I try this it keeps coming up with an error about RCP can't be turned on? Any ideas as to what the problem might be? I'm using IOS version 12.4(6)T advanced ip ...
THe other option is to manually tftp the needed files across - in that case, what files are needed for an 877?
Thanks, Steve
