help for switch to switch connection
Jul 18, 2007 1 Replies
Hi all,
i have two 2950 switches, and i wanna to connect them with a Straight- Through cable.
i know it should be easy to fixed by using cross cable, but my case is not easy to re-install cross cable =(
so any idea, or can it be config a uplink port for one 2950 switch?
thanks
steve
So make up a six inch cross cable and crimp a male connector on one end and a female connector on the other.
Or go buy a pre-built doohickey that will do the same thing. Web search for "Ethernet Crossover Adapter" pulls some useful hits.
