Can I connect switch port of Router to uplink on another switch to add more PC's
May 22, 2005 3 Replies
Most relevant reply
$Bill
Some switches can auto detect on all ports and others only on one and some on none (requiring a cross-over cable). You should check the docs for your brand. The easy thing to do is just try it and see what works and what doesn't. I'd start with a straight thru cable from the…
I have Cable modem contains Ethernet connection, which is connected to Braodband Router's WAN port, there are 4 LAN port's on Broadband Router, out of 4, 3 PC's connected to three LAN port's of switch, I need to add 6 more PC's, I got a workgroup switch, contains one Uplink and 8 LAN ports, can I connect the Uplink of the work group switch directly to one of the switch port of the Router? Or can I connect switch port of the work group to Router?.
Why some switches contaikns uplink and some don't, what was the exact difference, what this uplink makes difference?. Thanks in advance.
Some switches can auto detect on all ports and others only on one and some on none (requiring a cross-over cable). You should check the docs for your brand. The easy thing to do is just try it and see what works and what doesn't. I'd start with a straight thru cable from the uplink port and if that doesn't work try a switch port.
Normally, you'd connect the uplink port to the router.
Some are autosense, some require a crossover cable., some have a switch, on one port, to change modes, Also, gigabit doesn't need a special port or crossover.
