HELP! Cisco 2610 stuck in boot loop!
Aug 28, 2006 3 Replies
Jump to replies (3)
Hi Ivan,
You may wish to investigate ROMmon Recovery for the Cisco 2600 Series Router:
Sincerely,
Brad Reese Cisco IOS Software - Compatible Partner Matrix by Technology
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272 Fax: 775-254-3558 AIM: R2MGrant BradReese.Com - Global Cisco Systems Pre-Sales Support
Send a serial break within 30 seconds of poweron while booting. issue the tftpdwnld command (to see what variables need to be set, then set them appropriately) and TFTP the new IOS image down to the router.
It will take you at least 30 minutes to put an boot images ios to the rom.
We buy sell all Cisco, Discount up to 80% off on New Used Cisco. LinkWaves Corp
29980 Technology Drive, Suite 6 Murrieta, CA 92563
Ivan82 wrote:
