Multicast group limitation
Aug 28, 2006 1 Replies
Multicast group limitation open original image
We are using 3560 and 3750 PoE switches in a network which interconnects a lot of clients using a proprietary VoIP software solution.
This Software uses Multicast groups for communication and now we are running into the limitation of 1000 multicast groups supported by these switches.
Does anybody know if there is any possibility to extend the maximum number of Multicast groups on the 3560 and 3750 Cisco switches? IOS update? Memory extension?
Thanks in advance for your help
Hi Johannes,
Jaedeok Kim, CCIE and Cisco Systems Customer Support Engineer Email: tokim *at* cisco.com Telephone: +82 82-2-3429-7885
Provides the following information:
Currently, we support only 1024 multicast routes+IGMP groups.
To extend the maximum number, we need code changes.
At the moment, no code changes planned.
Hope this helps.
Brad Reese Cisco IOS Software - Compatible Partner Matrix by Technology
Hendersonville Road, Suite 17 Asheville, North Carolina USA 28803 USA & Canada: 877-549-2680 International: 828-277-7272 Fax: 775-254-3558 AIM: R2MGrant BradReese.Com - Global Cisco Systems Pre-Sales Support
