G.703 to Fastethernet Conversion.
Apr 12, 2007 0 Replies
HI,
I need to convert G.703 ( E1) unframed 2 MBPS ful to fast Ethernet. E1 is coming from Cisco 7609 Router. I have tested Patton 2701/I model E1 to ethernet conv. and LOOP 1510 Conv. but nothing is working. PLease let me know whether I am thinking rightly and doing it rightly.
Simple, I gave a hard loop at ethernet end and tried to see loop at ethernet side of the medai converter with the helpf of a 2800 series router bu the router shows line protocoal is up but nothing happens if i disconnect the loop(rx and tx short). If i gave a hard loop to the ethernet side of the mdia converter, I am not able to see the loopback from router at E1 side of the media converter.
PLease suggest!!!!!!!!!!!
Does Cisco 7609 has any compatibility or inter-operability issues, if yes which media converter make & model can work .
Waiting for an answer..
Thanks
Samir Ahsan
+91 9419011440, +91 9906685220
