escape sequence
Apr 12, 2005 1 Replies
Using windows commnad prompt and telneting into a router I trace to certain devices. If for some reason this fails I would like to abort the trace. Could anyone tell me what the escape sequence is? The message on trace is
"Type escape sequence to abort"
Thx...
The default is [Control]^
To get that you carry out the folowing. On US and UK keyboards anyway.
Press and hold the Shift and Control keys. The left ones work. Then press and release the 6 key.
It is complicated since ^ is [Shift]6 so to get [Cntrl]^ you need to press
[Shitf][Cntrl]^
Good luck.
