no enable prompt
Jan 10, 2008 7 Replies
Jump to replies (7)
no enable prompt open original image
Hi all,
I have a Cisco switch which is configured to use TACACs authentication. When I SSH to the switch and enter my user name and password, I am being logged to privileged level 15 (the switch does not prompt me for the enable password!). I want to disable this, but I cannot figure out what is causing it. I have checked configuration of my vty's and no privilege level is defined there. There is nothing wrong with my tacacs server either, since other switches that use it force me to enter enable password. Could you please tell me what besides "privilege level x" on VTY's can cause this single switch to behave this way?
Thanks, AL
Check below, is your switch and IOS is in list of effected ones.
Rgds.... NONU
Al,
Can you please paste the configuration related to VTY 0 4 & VTY 5 15?
Regards, Andy
Thanks CK. My switch (3750G) does not seem to be affected.
Andy, my VTYs are quite simple:
line con 0 exec-timeout 0 0 privilege level 15 line vty 0 4 transport input telnet ssh line vty 5 15 transport input telnet ssh !
This most likely is an attribute coming from the AAA server. The proper way to turn it off would be to do it on a selective basis on the AAA server. If this is not possible, the command in your configuration that tells the device to consider authorization from AAA would be:
aaa authorization exec group tacacs
Just remove this line and it will disable the behavior for everyone.
Scott
snipped-for-privacy@vp.pl wrote:
Scott, I do not have this line in my running configuration. The only AAA lines are:
aaa new-model aaa authentication enable default group tacacs+ enable aaa authentication login default group tacacs+ local aaa accounting exec default start-stop group tacacs+ aaa session-id common
I'm going to suspect it has something to do with:
which says the enable password should be verified against the tacacs server and fail back to the local enable password if the tacacs server is not available.
If you haven't tried it already, remove this line to see if there is any change in the behavior.
Scott
