831 Router with virtual AUX; no prompt
Dec 15, 2006 1 Replies
831 Router with virtual AUX; no prompt open original image
I have 80 branch offices with 831 routers & US Robotics modems connected via console port for out-of-band dialin. My problem is my service provider can dialin and make configuration changes with no problem however I am unable to.
I have used both Procomm Plus and HyperTerminal programs. I have set to
8-n-1 @ 9600, Flow Control = None and Emulation is set to "Auto Detect". I can connect to each branch, but I never receive a prompt after hitting the "Enter" key.
What am I missing in my PC setup? Thanks for any help!
Router Config: line con 0 exec-timeout 120 0 password 7 login modem enable transport preferred all transport output all stopbits 1 line aux 0 password 7 login transport preferred none transport output all
When a console cable ( usually a flat cable ) is connected from a Communication (COM) serial port of a PC to the router, and the correct configuration settings are applied to the Hyperterminal, a router prompt should appear on the screen after pressing the Enter key.
If the correct settings are not applied, the console port outputs garbage characters or no output at all. This makes the router appear as if it is hanging or not responding.
For more cabling information, refer to:
Cabling Guide for Console and AUX Ports
To resolve this issue, perform these steps:
Step 1. Connect the console cable from the console port of the router to the COM port of the PC.
Open the Hyperterminal on the PC, select the correct COM port, and use these settings:
Speed: 9600 bps
Databits: 8
Parity bits: 0
Stop bit: 1
No flow control
For further instructions, refer to:
Applying Correct Terminal Emulator Settings for Console Connections
Step 2. If this fails to solve the problem, swap cables or test the console cable.
This is done by attaching the console cable to the console port of another router.
Step 3. If the problem remains, the configuration register of the router may be set to a non-standard value for which the console connection speed is higher than 9600 bps.
If you can access the router through a Telnet session, check the value of the configuration register by issuing the show version command.
Ensure that it is set to 0x2102 or 0x102.
Reload the router for a configuration register change to take effect.
Change the configuration register by issuing the config-register command.
If the router has not been configured to accept a Telnet session, try different connection speeds.
These are valid connection speeds for Cisco routers:
1200 bps
2400 bps
4800 bps
9600 bps
19200 bps
38400 bps
57600 bps
115200 bps
Once you have gained access to the router, change the line speed to the default setting, as shown:
Router> enable Router#configure terminal Enter configuration commands, one per line. End with CNTL/Z. Router(config)#configure terminal Router(config)#config-register 0x2102 Router(config)#line con 0 Router(config-line)# speed 9600
Once you change the console speed, you lose connectivity.
Go to your terminal program, change the baud rate to 9600, and reconnect to the router console, as shown:
Router(config-line)#ctrl z Router #write memory Router #reload
If this method does not help for the Cisco 2600 and 3600 series platforms, refer to:
Cisco 2600 and 3600 Console Baud Reset Jumper
of Cisco 2600 and 3600 Hints and Tricks web page
Step 4. If in addition to not responding to the console, the router has stopped responding to queries sent from the network, such as Telnet or Simple Network Management Protocol (SNMP), refer to:
Troubleshooting Router Hangs
Step 5. If none of these steps are helpful, there is a problem with the console port on the router.
To solve the problem, swap the router chassis.
Hope this helps.
Brad Reese
