E1 connection
Nov 26, 2005 3 Replies
Jump to replies (3)
E1 connection open original image
Hello We are changing ISP New ISP did provide RJ45 to our office After 2 days someon called me and said that is not Ethernet connection - it is E1 (G.703) Connection
I hav router 3640 wirf FE -PRI interface (1FE-2CE1-B/U) 2 CTRLR and FastEthernet interfaces
wan network settings (xxx.xxx.xxx.aaa - xxx.xxx.xxx=fake aaa=real) Both WAN and LAN are PUBLIC ISP provided some informations
WAN settings Wan network: 80.80.80.156 WAN interface: 80.80.80.158 WAN remote: 80.80.80.157 WAN subnet mask 255.255.255.252
Lan Settings LAN network: 80.80.73.16 Lan Gateway: 80.80.73.17
1st usable IP: 80.80.73.18 Last usable IP: 80.80.73.31 network mask: 255.255.255.240
Question is Is this Interface is Correct? can I use FE-PRI How to configure this interface if Yes?
Thank You Robert
The CE devices are for ISDN. I think although not 100% sure you need something like this -
or buy a G.703 to X21 convertor and plug a WIC1T into the 3640.
Cheers
Matt
or a WIC-1MFT-G703
I will connect Matrodata DC1000 and than E1 (G.703 to WIC-T1 card (X.21) and than Ethwernet
