Spoofing on ADSL dialer interfaces
Feb 02, 2006 0 Replies
Hi, have a cisco router setup with 2x 2m adsl lines and configured for load sharing.. however.. getting spoofing messages on both the dialer interfaces.. see config below.. any ideas what this could be? misconfiguration? thanks in advance.
-------------------------------------------------------- mta receive maximum-recipients 0 ! interface ATM0/0 no ip address ip load-sharing per-packet no atm ilmi-keepalive pvc 0/38 encapsulation aal5mux ppp dialer dialer pool-member 1 ! dsl operating-mode auto ! interface FastEthernet0/0 ip address X.X.X.X 255.255.255.252 ip accounting output-packets ip accounting mac-address input ip accounting access-violations ip load-sharing per-packet speed 10 full-duplex no keepalive ! interface ATM0/1 no ip address ip load-sharing per-packet no ip route-cache no ip mroute-cache no atm ilmi-keepalive pvc 0/38 encapsulation aal5mux ppp dialer dialer pool-member 2 ! dsl operating-mode auto ! interface FastEthernet0/1 no ip address shutdown duplex auto speed auto ! interface Dialer0 ip address negotiated ip access-group 101 in ip load-sharing per-packet encapsulation ppp dialer pool 1 dialer idle-timeout 0 dialer-group 1 ppp chap hostname snipped-for-privacy@adslprovider.co.uk ppp chap password 7 043444444444444 ! interface Dialer1 ip address negotiated ip load-sharing per-packet encapsulation ppp no ip route-cache cef dialer pool 2 dialer-group 2 ppp chap hostname name_2 snipped-for-privacy@adslprovider.co.uk ppp chap password 7 33333333333333 ! ip classless ip route 0.0.0.0 0.0.0.0 Dialer0 ip route 0.0.0.0 0.0.0.0 Dialer1
ADSL-2621#sho int dialer 0 Dialer0 is up, line protocol is up (spoofing) Hardware is Unknown Internet address is X.X.X.X/32 MTU 1500 bytes, BW 56 Kbit, DLY 20000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation PPP, loopback not set DTR is pulsed for 1 seconds on reset Interface is bound to Vi3 Last input never, output never, output hang never Last clearing of "show interface" counters 01:18:17 Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: weighted fair Output queue: 0/1000/64/0 (size/max total/threshold/drops) Conversations 0/0/16 (active/max active/max total) Reserved Conversations 0/0 (allocated/max allocated) Available Bandwidth 42 kilobits/sec 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 63052 packets input, 27941654 bytes 45525 packets output, 11331064 bytes Bound to: Virtual-Access3 is up, line protocol is up Hardware is Virtual Access interface MTU 1500 bytes, BW 56 Kbit, DLY 100000 usec, reliability 255/255, txload 95/255, rxload 236/255 Encapsulation PPP, LCP Open Listen: CDPCP Open: IPCP PPPoATM vaccess, cloned from Dialer0 Bound to ATM0/0 VCD: 1, VPI: 0, VCI: 38, loopback not set DTR is pulsed for 5 seconds on reset Interface is bound to Di0 (Encapsulation PPP) Last input 00:00:03, output never, output hang never Last clearing of "show interface" counters 01:18:17 Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: fifo Output queue: 0/40 (size/max) 5 minute input rate 52000 bits/sec, 12 packets/sec 5 minute output rate 21000 bits/sec, 11 packets/sec 63053 packets input, 27943076 bytes, 0 no buffer Received 0 broadcasts, 0 runts, 0 giants, 0 throttles 0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored, 0 abort 45526 packets output, 11331714 bytes, 0 underruns 0 output errors, 0 collisions, 0 interface resets 0 output buffer failures, 0 output buffers swapped out 0 carrier transitions ADSL-2621# ADSL-2621#sho int dialer 1 Dialer1 is up (spoofing), line protocol is up (spoofing) Hardware is Unknown Internet address will be negotiated using IPCP MTU 1500 bytes, BW 56 Kbit, DLY 20000 usec, reliability 255/255, txload 1/255, rxload 1/255 Encapsulation PPP, loopback not set DTR is pulsed for 1 seconds on reset Last input never, output never, output hang never Last clearing of "show interface" counters 01:18:19 Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0 Queueing strategy: weighted fair Output queue: 0/1000/64/0 (size/max total/threshold/drops) Conversations 0/0/16 (active/max active/max total) Reserved Conversations 0/0 (allocated/max allocated) Available Bandwidth 42 kilobits/sec 5 minute input rate 0 bits/sec, 0 packets/sec 5 minute output rate 0 bits/sec, 0 packets/sec 0 packets input, 0 bytes 0 packets output, 0 bytes ADSL-2621#
