Routing table metric.
Mar 20, 2006 2 Replies
Is it possible to higher a metric for network directly connected on the router? It is quite long to explain but first of all I would like to know if what I asked it is possible. I mean if the router reports
192.168.100.0/24 directly connected on dialer0
Can I modify the routing table with
ip route 192.168.100.0 255.255.255.0 dialer 0 100 ?
Do the networks directly connected to the interfaces take precedence over all the other routing informations?
Alex.
Alex,
I'm reasonably sure that there's no way to change the administrative distance for a connected route.
I suppose you could do policy routing, but here's what I think is an easier approach:
- instead of giving d0 an address in 192.168.100/24, unnumber it to a local loopback or LAN interface
- configure a floating static to 192.168.100/24 via d0
Cheers,
Aaron
Yes
A floating static route would never defeat a directly connected route for 192.168.100.0
What is the problem that you are trying to address ?
