dhcp cisco806 basic setup question/problem...
Jul 22, 2006 4 Replies
Jump to replies (4)
I have a cisco 806 router.
Two(2) ethernet ports on the router.
Ethernet1 is connected to the internet, (receiving it's ip from an external dhcp server).
Ethernet0 is connected to my LAN,(static routing is working fine).
I want the router to assign IP's to internal machines,(which don't have static IPs assigned), using dhcp. The IP's it is to assign are the range: 192.168.0.129192.168.0.254.
It wont assign anything! What am I missing?
Partial config follows: /////////////////////////////////////////// ! version 12.2 ! ip dhcp pool main import all network 192.168.0.128 255.255.255.128 default-router 192.168.0.1 ! interface Ethernet0 ip address 192.168.0.1 255.255.255.0 no ip redirects ip nat inside no cdp enable hold-queue 32 in hold-queue 100 out ! interface Ethernet1 ip address dhcp no ip unreachables ip nat outside no cdp enable ! ip nat inside source list 101 interface Ethernet1 overload ! access-list 101 permit ip 192.168.0.0 0.0.0.255 any ! ///////////////////////////////////////////
  1. Please post izOS version in use
  1. Suggested config change
! configure default route
ip route 0.0.0.0 0.0.0.0 dhcp
  1. debug DHCP
conf t logging buffer 10000 debug no logging console end
wri mem
clear log debug ip dhcp server events debug ip dhcp server packets
Post debug output
Version 12.2(2) "flash:c806-sy6-mz.122-2.XI.bin"
dhcp is not an option here.
I do this a lot and it works.
I have no idea if this is the issue however your DHCP pool and your LAN address have inconsistent netmasks.
ip dhcp excluded-address 192.168.0.1 192.168.0.127 ip dhcp pool main import all network 192.168.0.0 255.255.255.0 default-router 192.168.0.1
Is what I use.
Merv said:- ip route 0.0.0.0 0.0.0.0 dhcp
Thanks. Not seen that one, in the UK ADSL is usually PPPoA.
Thanks, that did the job!
