Connection Problems Cisco Catalyst 4503 & Sunfire 240
Feb 22, 2007 1 Replies
Hello,
i have a problem that the connection with a Sunfire 240 does not work on
1 Gbit Speed. 10/100 Full/half is nor problem but if i change the server to 1Gbit the connection goes down.
Has anyone and idea or maybe the same problem ?
Regards Marco
Maybe you've connected it to a 10/100 port?
For GigE I think that you are supposed to leave it to negotiate, not hard set it. What does the port on the 4503 show?
Chris.
