Team Requesting Help Cisco 3750 one way ping
Jan 22, 2006 5 Replies
Jump to replies (5)
I am adding a newly installed 3750 switch to a layer 3 6509 switch via fiber in addition I have created a new VLAN on swiitch and added the vlan to the MSFC.
They are using trasparent mode for the vtp mode
Here is my problem I have a Cisco 3750 that I am trunking to a 6509 switch.
I can not ping my msfc from my switch, in addition I can not ping the locally attached workstation
I can ping from my workstation to the msfc, and other devices in the network, but I can not recieve pings from other devices in the network only the MSFC from my laptop
I recieve my dhcp request and can surf the net so I know that I don't have a connectivity problems.
I have attached my configuration from the 3750
sh run Building configuration...
Current configuration : 7027 bytes ! version 12.2 no service pad service timestamps debug uptime service timestamps log uptime no service password-encryption ! hostname CSBHP6B1-113D01 ! ! no aaa new-model switch 1 provision ws-c3750-48ts vtp domain vtp mode transparent ip subnet-zero ! ! ! ! no file verify auto spanning-tree mode pvst spanning-tree extend system-id ! vlan internal allocation policy ascending ! vlan 2,113 ! ! interface FastEthernet1/0/1 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/2 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/3 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/4 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/5 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/6 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/7 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/8 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/9 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/10 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/11 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/12 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/13 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/14 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/15 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/16 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/17 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/18 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/19 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/20 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/21 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/22 switchport access vlan 113 duplex full speed 100 spanning-tree portfast
interface FastEthernet1/0/23 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/24 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/25 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/26 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/27 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/28 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/29 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/30 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/31 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/32 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/33 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/34 switchport access vlan 113 --More--   duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/35 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/36 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/37 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/38 --More--   switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/39 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/40 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/41 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! --More--  interface FastEthernet1/0/42 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/43 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/44 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/45 switchport access vlan 113 duplex full speed 100 spanning-tree portfast --More--  ! interface FastEthernet1/0/46 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/47 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface FastEthernet1/0/48 switchport access vlan 113 duplex full speed 100 spanning-tree portfast ! interface GigabitEthernet1/0/1 description to CSBHP6B1-132d01 3/7 switchport trunk encapsulation dot1q switchport trunk native vlan 2 switchport access vlan 113 switchport trunk allowed vlan
1,2,4,78,113,114,250,850,851,853,998,1002-1005 switchport mode trunk speed nonegotiate ! interface GigabitEthernet1/0/2 ! interface GigabitEthernet1/0/3 ! interface GigabitEthernet1/0/4 ! interface Vlan1 no ip address ! interface Vlan2 ip address 10.1.175.9 255.255.255.0 ! ip default-gateway 10.1.175.1 ip classless ip route 0.0.0.0 0.0.0.0 Vlan2 10.1.175.1 ip route 0.0.0.0 0.0.0.0 Vlan2 1.175.1.10 ip http server ! ! --More--  ! control-plane ! nforcement officials. ^C ! line con 0 line vty 0 4 no login --More--  line vty 5 15 no login ! ntp server ntp server ! end
#sh ip int bri Interface IP-Address OK? Method Status Protocol Vlan1 unassigned YES NVRAM up up Vlan2 10.1.175.9 YES NVRAM up up unassigned YES unset down down F unassigned YES unset down down GigabitEthernet1/0/1 unassigned YES unset up up GigabitEthernet1/0/2 unassigned YES unset down down GigabitEthernet1/0/3 unassigned YES unset down down GigabitEthernet1/0/4 unassigned YES unset down down CSBHP6B1-113D01#    sh vlan
VLAN Name Status Ports
1 default active Gi1/0/2, Gi1/0/3, Gi1/0/4
2 VLAN0002 active
113 VLAN0113 active Fa1/0/1, Fa1/0/2, Fa1/0/3 Fa1/0/4, Fa1/0/5, Fa1/0/6 Fa1/0/7, Fa1/0/8, Fa1/0/9 Fa1/0/10, Fa1/0/11, Fa1/0/12 Fa1/0/13, Fa1/0/14, Fa1/0/15 Fa1/0/16, Fa1/0/17, Fa1/0/18 Fa1/0/19, Fa1/0/20, Fa1/0/21 Fa1/0/22, Fa1/0/23, Fa1/0/24 Fa1/0/25, Fa1/0/26, Fa1/0/27 Fa1/0/28, Fa1/0/29, Fa1/0/30 Fa1/0/31, Fa1/0/32, Fa1/0/33 Fa1/0/34, Fa1/0/35, Fa1/0/36 Fa1/0/37, Fa1/0/38, Fa1/0/39 Fa1/0/40, Fa1/0/41, Fa1/0/42 Fa1/0/43, Fa1/0/44, Fa1/0/45 Fa1/0/46, Fa1/0/47, Fa1/0/48
1002 fddi-default act/unsup
1003 token-ring-default act/unsup --More--   VLAN Name Status Ports
1004 fddinet-default act/unsup
1005 trnet-default act/unsup
VLAN Type SAID MTU Parent RingNo BridgeNo Stp BrdgMode Trans1 Trans2
1 enet 100001 1500 - - - - - 0
0
2 enet 100002 1500 - - - - - 0
0
113 enet 100113 1500 - - - - - 0
0
1002 fddi 101002 1500 - - - - - 0
0
1003 tr 101003 1500 - - - - - 0
0
1004 fdnet 101004 1500 - - - ieee - 0
0
1005 trnet 101005 1500 - - - ibm - 0
0
Remote SPAN VLANs
Hello,
you might want to configure the 6509 as VTP server, and the 3750 as VTP client. I think the problem is that, since the VTP mode is transparent, no VLAN information is exchanged. Make sure the VTP domain name (case-sensitive) matches on both sides...
HTH,
snipped-for-privacy@solutionfinders.nl
We=B4ve got answers !
I did not see that tested in the original post
Post results of the following tests:
Test
Reachable
  1. from your PC, ping MSFC VLAN 2 IP address 10.1.175.1 ???
  2. from new 3750 switch, ping MSFC VLAN 2 IP address 10.1.175.1 (its default gateway) ???
  3. from your PC, ping 3750 VLAN 2 IP address 10.1.175.9 ???
This reads like a routing problem. Check the routing table 3750 and
6509 MSFCs. The 3750 doesn't have a layer 3 interface in vlan 113 which forces it to follow it's routing table to the 6509. For the 3750 to ping a client on same switch it has to follow its routing table and route traffic to 10.1.175.1 and 1.175.1.10 (I'm assuming this a typo). Create a vlan113 interface on the 3750 and try pinging a client and the MSFC's vlan113 IP. Next check the 6509 to see if it has a layer-3 vlan2 interface in the MSFC and that it is up. Also doublecheck the allowed vlans and make sure that vlan2 is permitted on the 6509s interface. J
Guy's thanks so much, I later figured out the problem, but you were correct I needed to add an IP address to VLAN interface 113. I forgot we had ran out of IP address for orginal vlan 2.
