VPN Connection thru ASA5500 Problem
Jan 18, 2008 5 Replies
Jump to replies (5)
VPN Connection thru ASA5500 Problem open original image
Hello Everyone, I've configured and installed a new ASA5500 at home and everything is working except outgoing VPN connections. I run the Cisco VPN client and connect to 'Work' and it appears to build the tunnel, however I cannot access anything on the remote network. An 'ipconfig/all' shows that I've received an IP address on the remote network; just can't get to anything. If I swap my old router back in place, I am able to connect and access all remote network resources. VPN server on the 'Work' side is an ASA5510. I appreciate your time and any help you can provide, Dave.
Here's my current running-config:
Result of the command: "sh run"
: Saved : ASA Version 7.2(2) ! hostname home domain-name domain.net enable password xxxxxxxxxxxxxxxxx encrypted names ! interface Vlan1 nameif inside security-level 100 ip address 192.168.1.1 255.255.255.0 ! interface Vlan2 nameif outside security-level 0 ip address dhcp setroute ! interface Vlan3 no nameif security-level 50 no ip address ! interface Ethernet0/0 switchport access vlan 2 ! interface Ethernet0/1 speed 100 duplex full ! interface Ethernet0/2 speed 100 duplex full ! interface Ethernet0/3 speed 100 duplex full ! interface Ethernet0/4 speed 100 duplex full ! interface Ethernet0/5 speed 100 duplex full ! interface Ethernet0/6 speed 100 duplex full ! interface Ethernet0/7 speed 100 duplex full ! passwd xxxxxxxxxxxxxxxxxx encrypted ftp mode passive clock timezone EST -5 clock summer-time EDT recurring dns domain-lookup inside dns domain-lookup outside dns server-group DefaultDNS name-server xx.xx.xx.xx name-server xx.xx.xx.xx domain-name domain.net pager lines 24 logging enable logging asdm informational mtu inside 1500 mtu outside 1500 icmp unreachable rate-limit 1 burst-size 1 asdm image disk0:/asdm-522.bin no asdm history enable arp timeout 14400 global (outside) 1 interface nat (inside) 1 0.0.0.0 0.0.0.0 timeout xlate 3:00:00 timeout conn 1:00:00 half-closed 0:10:00 udp 0:02:00 icmp 0:00:02 timeout sunrpc 0:10:00 h323 0:05:00 h225 1:00:00 mgcp 0:05:00 mgcp-pat
0:05:00 timeout sip 0:30:00 sip_media 0:02:00 sip-invite 0:03:00 sip- disconnect 0:02:00 timeout uauth 0:05:00 absolute http server enable http xx.xx.xx.xx xxx.xxx.xxx.xxx inside no snmp-server location no snmp-server contact snmp-server enable traps snmp authentication linkup linkdown coldstart telnet xx.xx.xx.xx xxx.xxx.xxx.xxx inside telnet timeout 5 ssh xx.xx.xx.xx xxx.xxx.xxx.xxx inside ssh timeout 5 console timeout 0 dhcpd auto_config outside ! dhcpd address xx.xx.xx.xx-xx.xx.xx.xx inside dhcpd dns xx.xx.xx.xx xx.xx.xx.xx interface inside dhcpd enable inside !
! class-map inspection_default match default-inspection-traffic ! ! policy-map type inspect dns preset_dns_map parameters message-length maximum 512 policy-map global_policy class inspection_default inspect dns preset_dns_map inspect ftp inspect h323 h225 inspect h323 ras inspect rsh inspect rtsp inspect esmtp inspect sqlnet inspect skinny inspect sunrpc inspect xdmcp inspect sip inspect netbios inspect tftp ! service-policy global_policy global prompt hostname context Cryptochecksum: xxxxxxxxxxxxxxxxxxxxxxxxxx : end
On the work firewall enter the command "isakmp nat-traversal 20". You are comming from behind a "real" firewall now that does true NAT/PAT and the work firewal needs to be configured to allow that.
Hi
The problem is not on your side. The Firewall where you connect to must configured with nat traversal. On a cisco box (asa/pix) its like this:
crypto isakmp nat-traversal 20
or on older os's:
cu
"dave" wrote
Enable ipsec-pass-thru:
policy-map global_policy class inspection_default inspect ipsec-pass-thru
see:
for details
Jens
Jens, please correct me, but with the pass-thru command, you can't have other vpn connections on the outsite interface.
Ok on this example it's not a problem, but for others, i think that's an importand point.
cu ivo
wrote
You are right about Pix 6.x versions but I am not sure that this also applies to ASA 7.x and 8.x versions. The DocCD does not mention it. I might test it if I find the time. On the other hand his requirement was to connect to work and this might be the only solution as depending on his position I doubt that the VPN Admins will change the setup only because of him.
Jens
