EAP-TLS for Aironet 1231 ?
Mar 24, 2006 4 Replies
Uli Link
The AP authenticates to the RADIUS by IP address and a shared secret. No. An Aironet 1230 internal radius server can only authenticate LEAP or EAP-FAST. For EAP-TLS you'll need another RADIUS like M$ IAS, Cisco ACS or Funk Steel Belted RADIUS. Together with an external RADIUS…
is there a chance to let the accesspoint do an authentication additionally to the clients ?
is there a functionality on the accesspoints to start EAP-TLS authentication and authenticate with machine certificate ?
and i think for that you will need this "multiple authentication" feature on the switch don=B4t you ? Does anyone know the right name of this feature ?
Thanks a lot Greetz Eric
No.
An Aironet 1230 internal radius server can only authenticate LEAP or EAP-FAST. For EAP-TLS you'll need another RADIUS like M$ IAS, Cisco ACS or Funk Steel Belted RADIUS. Together with an external RADIUS the AIR 1230 will support multiple EAP-TLS authenticatet client stations.
with that i meant authentication via switch and not via accesspoint. should have write this more clearly. i don=B4t know the right name of the feature to do multiple authentication on the same port.=20
Greetz Eric
with that i meant authentication via switch and not via accesspoint. should have write this more clearly. i don´t know the right name of the feature to do multiple authentication on the same port.
Sounds to me like 802.1x auth towards the switchport of the switch that the AP connects to, right ? I am not 100% into the Cisco lingo about dot1x, but the commands are called that (dot1x) As how to install a CERT into the AP, I would look it up on CCO or at your local partner.
HTH Martin Bilgrav
Note that FreeRadius works fine as well.
