commnd to chagne gateway
Sep 02, 2006 2 Replies
Cisco 1601 I have a [seemingly] simple change to make to several Cisco 1600 devices. Each has a gateway assigned = 10.10.10.254 and I need to change the gateway to 10.10.10.251
Rather than spend $$$ for Qwest to make the changes, and they certainly can do it easily, I have been asked to see if we can make the change. If this is a relatively straightforward command(s), could someone describe the syntax? I have "en" access to the devices, and I have a test device to work with.
Oh, and to change a subnet from 255.255.255.0 to 255.0.0.0 --?--
I'm on my way to Barnes & Noble and to Borders to read and maybe purchase a book or two. I do not intend to make a living with my limited Cisco skills, just need to get past this hurdle.
The syntax is:
ip route 0.0.0.0 0.0.0.0 10.10.10.251
If you have them all talking EIGRP then you only have to make the change in one of them.
Consider this topology:
All internal routers --- (10.0.0.251) / (its default route) --- the default location
---------------------------------- In 10.0.0.251:
router eigrp 1 network 10.0.0.0 redistribute static
---------------------------------- In other routers:
The other routers will receive the default route from that router.
BTW .. what is the impact to the business if these changes don't get done properly? Downtime costs $. Is it cheaper and safer to get Qwest in?
BernieM
thanks for the info - and I agree on having Qwest involved - as the downtime costs more than the change. Looking through the books last night was interesting. I'll be working with people later this week that have only known GUI - my guess is we will be scheduling Qwest help by this coming Friday.
But you will get the credit for the testing we're doing. Again thanks!
Chuck
