Cisco QoS
Dec 03, 2008 1 Replies
I am wanting to enable QoS on my cisco 3620 router for my VoiP traffic. I know this can be done using ACL's instead of SDM. Can anyone point me to a tutorial or an howto of how to do this?
Thanks,
of Service for Voice over IP
LLQ is the suggested method for this now however the 3620 has been around for some time now and depending on the software on it, it is possible that you may not be able to use LLQ. The "command reference guide" lists the software version where commands were introduced.
In general - one approach is to use the SDM for an initial setup and then to work forther from the command interface.
