Cisco QOS
Jan 29, 2006 1 Replies
Hi all
Is it possible to configure QOS to prioritise traffic on certai ports using Cisco 800 with Version 12.2(15)T2?
Thanks
Judging from my recent experience you will have to try it.
3725 with ADSL WIC will not actually do LLQ. as far as I can see, in my configuration.
I have done this before on an 837 and it worked.
c3725-advipservicesk9-mz.123-8.T3.bin
I get occasional messages regarding MLPPP and I have found some docs that say that MLPPP is needed for LLQ. Trouble is the ISP doesn't do it.
class-map match-any CM-voice match dscp ef match dscp cs3 ! ! policy-map PM-tointernet class CM-voice priority 270 class class-default fair-queue queue-limit 10
interface ATM0/0 description ADSL Connection to Internet no ip address no atm ilmi-keepalive dsl operating-mode auto dsl enable-training-log pvc 8/35 tx-ring-limit 16 vc-hold-queue 4 pppoe-client dial-pool-number 1
interface Dialer1 bandwidth 512 ip address negotiated ip access-group 190 in ip nat outside ip virtual-reassembly service-policy output PM-tointernet encapsulation ppp ip route-cache flow dialer pool 1 dialer-group 1
sh policy-map int d1 Dialer1
Service-policy output: PM-tointernet
Class-map: CM-voice (match-any) 36800 packets, 5040688 bytes 5 minute offered rate 0 bps, drop rate 0 bps Match: dscp ef 0 packets, 0 bytes 5 minute rate 0 bps Match: dscp cs3 36800 packets, 5040688 bytes 5 minute rate 0 bps Queueing Strict Priority Output Queue: Conversation 136 Bandwidth 270 (kbps) Burst 6750 (Bytes) (pkts matched/bytes matched) 0/0 (total drops/bytes drops) 0/0
Class-map: class-default (match-any) 333367 packets, 85996282 bytes 5 minute offered rate 0 bps, drop rate 0 bps Match: any Queueing Flow Based Fair Queueing Maximum Number of Hashed Queues 128 (total queued/total drops/no-buffer drops) 0/0/0
Everything looks lined up but no actual QoS.
