tcpdump filters for data collection
Dec 03, 2008 3 Replies
Jump to replies (3)
I want to collect data on a network and map the data flow and system/port traffic. There are 2 scenarios of data collection here. The first is to collect IP traffic only. In this method I do not want the data portion of the IP packet (need IP address, source/destination ports etc).
The second is to collect traffic that will show all the routing protocols (non-IP) used on this network. Today while collecting the data, I saw several HSRP packets. I don't know what portion of the packet is sufficient to capture for this purpose.
I used the "-s 0" option on tcpdump which captures the whole packet. That is making the dump file large. Any help with the filters is appreciated to capture the non-data portion of the packets.
Thank you in advance.
NJ
Have you tried -s xx where xx is header size (or at least the size required to snaffle the data you want)?
-s 0 is clearly the opposite of what you want.
You might want to have a look at argus
collects flow data and has clients for manipulating it.
Peter Van Epp / Operations and Technical Support Simon Fraser University, Burnaby, B.C. Canada
In general - I capture to a file, and then process the results after. I filter when capturing only if necessary.
That way, things that might slow down the processing (DNS) won't affect the data capture.
The argument "ip" will only capture IP traffic ( and TCP/UDP, but not broadcast, etc.)
tcpdump -w file.tcpdump ip
You can use '-s #' and make sure # is small enough to just capture the header. The default (without -s at all) is usually sufficent. But unless there's a privacy issue, it's just a matter of ignoring the information you don't want to see.
Are you running two different captures?
Capturing (1) all IP and (2) all non-IP essentially says you are capturing everything.
Looking at the source (in print-udp.c) shows:
else if (dport == HSRP_PORT) hsrp_print((const u_char *)(up + 1), length); where #define HSRP_PORT 1985
so you can use the filter tcpdump .... udp and port 1985
