I have configured the 1200 access point with static ip address .wep key enabled and mac address filtering when ever i am trieing to access wifi i wiill not get the IP .IF i removed the mac fltering i will get the ip address from the server . please help me.
thanks preetham
Hi Jeff, We go way back, decades, regarding Fox's/Snit's childish rants...
B
Brian V
What do the logs say? More than likely you put in the wrong MAC address.
P
preetham
the logs are below
I m add in mac address of wireless ethernet only i checked the same also Mar 1 03:29:37.808 Information Interface Dot11Radio0, Deauthenticating Station 0013.02af.3ce6 Reason: Disassociated because sending station is leaving (or has left) BSS
2 Mar 1 03:06:58.234 Information Interface Dot11Radio0, Station ap_1
0013.02af.3ce6 Reassociated KEY_MGMT[NONE]
3 Mar 1 03:06:06.084 Information Interface Dot11Radio0, Deauthenticating Station 0013.02af.3ce6 Reason: Disassociated because sending station is leaving (or has left) BSS
4 Mar 1 03:06:06.084 Information Station 0013.02af.3ce6 Roamed to
0017.94d5.4740
5 Mar 1 03:02:44.682 Information Interface Dot11Radio0, Station ap_1
0013.02af.3ce6 Associated KEY_MGMT[NONE]
6 Mar 1 02:59:57.236 Information Interface Dot11Radio0, Deauthenticating Station 0013.02af.3ce6 Reason: Disassociated because sending station is leaving (or has left) BSS
7 Mar 1 02:59:57.236 Information Station 0013.02af.3ce6 Roamed to
0017.94d5.4740
8 Mar 1 02:50:13.770 Information Interface Dot11Radio0, Deauthenticating Station 0013.02af.3ce6 Reason: Disassociated because sending station is leaving (or has left) BSS
9 Mar 1 02:50:09.633 Information Interface Dot11Radio0, Station ap_1
10 Mar 1 02:41:34.391 Information Interface Dot11Radio0, Deauthenticating Station 0013.02af.3ce6 Reason: Disassociated because sending station is leaving (or has left) BSS
11 Mar 1 02:41:18.236 Information Interface Dot11Radio0, Station ap_1
B
Brian V
The client is roaming to another AP. 7 Mar 1 02:59:57.236 Information Station 0013.02af.3ce6 Roamed to 0017.94d5.4740
P
preetham
I added user mac address in both Access point if user roaming from one ap to two ap it should associate pelase brief me
B
Brian V
You need to post the log from the AP that you are associated to. You posted a log for the AP you were not on. It tells us nothing except that your on another AP.
P
preetham
Hi
Now i disable the other ap now only one ap is there now also same when mac filter enable it will not associate if we disable mac filter ap will associte to client the logs are below
Mar 2 21:51:53.470 Information Interface Dot11Radio0, Station
0016.6f1c.517c Associated KEY_MGMT[NONE] Mar 2 20:51:25.344 Information Interface Dot11Radio0, Deauthenticating Station 0013.02af.3ce6 Reason: Disassociated because sending station is leaving (or has left) BSS Mar 2 20:47:24.947 Information Interface Dot11Radio0, Station ap
0013.02af.3ce6 Associated KEY_MGMT[NONE] Mar 2 20:47:24.917 Information Interface Dot11Radio0, Deauthenticating Station 0013.02af.3ce6 Reason: Disassociated because sending station is leaving (or has left) BSS Mar 2 20:44:12.420 Information Interface Dot11Radio0, Station ap
Please do the needfull i m facing lot of problem
B
Brian V
You are still leaving the AP "Disassociated because sending station is leaving (or has left) BSS".
P
preetham
what is the next step for this what log says i am getting
B
Brian V
There is no next step on the AP. Your laptop is roaming to another AP or associating to another SSID. Thus far the logs have showed nothing wrong with the AP or the client, simply that it has left. You would need to troubleshoot your PC and find out why it is leaving.
Report Content
ASAP.
