Cisco 878 bridging?
Nov 03, 2006 2 Replies
Walter Roberson
An IOS router would only nat if you have "ip nat" statements. Get rid of those statements and it will just route. Bridging is used when you have ports (or VLANs on ports) that you want to belong to the same broadcast domain -- places where you want the device to act like a…
Can anyone direct me to bridging configuration examples on the 878 platform?
I need the router to run without NAT'in anything.
Bridging is used when you have ports (or VLANs on ports) that you want to belong to the same broadcast domain -- places where you want the device to act like a switch for traffic between those ports instead of acting like a router. Bridging has no relationship to NAT. For information on bridging, search for the "bridge-group" command.
Will do - thanx. Need to router as a media converter from sdsl -> ethernet
