Cisco 878
Apr 08, 2008 3 Replies
Jump to replies (3)
Hi all
I'm having trouble with an 878 SHDSL modem My startup config for the controller is
controller DSL 0 mode atm line-term cpe line-mode auto dsl-mode shdsl symmetric annex B line-rate 2048
Yet when I start the modem up the line rate changes to 1152
Show running
controller DSL 0 mode atm line-term cpe line-mode auto dsl-mode shdsl symmetric annex B line-rate 1152
I have to manually go in via the console cable and change the line-rate to 2048 before the modem will give me a connection
Any ideas please as to why it doesn't keep the settings in the startup config
Hate to ask the obvious, but you are doing a write mem or copy run start right?
Or have you tried line-rate auto? I'm having trouble finding any clear documentation that says you can or can't change that parameter, so I'm wondering if its a code issue or if auto might work.
