Cisco 871 - Wireless setup questions
May 26, 2006 3 Replies
Jump to replies (3)
I am trying to get an 871 soho router wireless connections to work. The SDM is useless. I have tried to find docs on how and why and what to do - but no luck. Been at the this for a week. Got the DSL and fw parts working, but not wireless.
I have a Authentication Open setup - guest-mode enabled. So I should be pretty wide open for connections. I can see the SSID on a client PC, but cannot connect. I'm running DHCP to clients
Any Ideas and help would be greatly appreciated.
post your current config so responders can determine what needs to be added.
Thanks in advance ...
871#sh run Building configuration...
Current configuration : 5737 bytes ! ! Last configuration change at 15:17:15 PCTime Fri May 26 2006 by mallard ! NVRAM config last updated at 20:28:27 PCTime Tue May 23 2006 by mallard ! version 12.3 no service pad service tcp-keepalives-in service tcp-keepalives-out service timestamps debug datetime msec localtime show-timezone service timestamps log datetime msec localtime show-timezone service password-encryption service sequence-numbers ! hostname 871 ! boot-start-marker boot-end-marker ! logging buffered 51200 debugging logging console critical enable secret 5 $1$h523$yTFRFTvNy2ur6gtr/NyC61 ! username xxxxxxxx privilege 15 secret 5 $1$K7KN$cUZxAt.vZ5pH7d9XphirL. clock timezone PCTime -6 clock summer-time PCTime date Apr 6 2003 2:00 Oct 26 2003 2:00 no aaa new-model ip subnet-zero no ip source-route ip cef ip dhcp excluded-address 192.168.0.1 192.168.0.100 ip dhcp excluded-address 192.168.0.110 192.168.0.254 ip dhcp excluded-address 192.168.0.109 ! ip dhcp pool sdm-pool1 import all network 192.168.0.0 255.255.255.0 default-router 192.168.0.109 ! ! ip inspect name DEFAULT100 cuseeme ip inspect name DEFAULT100 ftp ip inspect name DEFAULT100 h323 ip inspect name DEFAULT100 icmp ip inspect name DEFAULT100 netshow ip inspect name DEFAULT100 rcmd ip inspect name DEFAULT100 realaudio ip inspect name DEFAULT100 rtsp ip inspect name DEFAULT100 esmtp ip inspect name DEFAULT100 sqlnet ip inspect name DEFAULT100 streamworks ip inspect name DEFAULT100 tftp ip inspect name DEFAULT100 tcp ip inspect name DEFAULT100 udp ip inspect name DEFAULT100 vdolive ip tcp synwait-time 10 no ip bootp server no ip domain lookup ip domain name yourdomain.com no ftp-server write-enable ! ! ! ! ! bridge irb ! ! interface FastEthernet0 no ip address no cdp enable ! interface FastEthernet1 no ip address no cdp enable ! interface FastEthernet2 no ip address no cdp enable ! interface FastEthernet3 no ip address no cdp enable ! interface FastEthernet4 description $ES_WAN$$FW_OUTSIDE$$ETH-WAN$ no ip address no ip redirects no ip unreachables no ip proxy-arp ip route-cache flow duplex auto speed auto pppoe enable pppoe-client dial-pool-number 1 no cdp enable ! interface Dot11Radio0 no ip address ! ssid 1138 vlan 1 authentication open guest-mode ! speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0 36.0
48.0 54.0 station-role root no cdp enable bridge-group 1 bridge-group 1 spanning-disabled ! interface Vlan1 description $ETH-SW-LAUNCH$$INTF-INFO-HWIC 4ESW$$FW_INSIDE$ ip address 192.168.0.109 255.255.255.0 ip access-group 102 in ip nat inside ip virtual-reassembly ! interface Dialer1 description $FW_OUTSIDE$ mtu 1492 ip address negotiated ip access-group 103 in ip inspect DEFAULT100 out ip nat outside ip virtual-reassembly encapsulation ppp dialer pool 1 no cdp enable ppp authentication pap callin ppp pap sent-username snipped-for-privacy@xxxxxx.net password 7 096E470E14041B1E0A1E003F280F68 ppp ipcp dns request accept ! ip classless ip route 0.0.0.0 0.0.0.0 Dialer1 ! ip http server ip http authentication local ip http secure-server ip http timeout-policy idle 5 life 86400 requests 10000 ip nat inside source list 1 interface Dialer1 overload ! logging trap debugging access-list 1 remark INSIDE_IF=BVI1 access-list 1 remark SDM_ACL Category=2 access-list 1 permit 192.168.0.0 0.0.0.255 access-list 100 remark auto-generated by Cisco SDM Express firewall configuration access-list 100 remark SDM_ACL Category=1 access-list 100 deny ip host 255.255.255.255 any access-list 100 deny ip 127.0.0.0 0.255.255.255 any access-list 100 permit ip any any access-list 101 remark auto-generated by Cisco SDM Express firewall configuration access-list 101 remark SDM_ACL Category=1 access-list 101 deny ip 192.168.0.0 0.0.0.255 any access-list 101 permit icmp any any echo-reply access-list 101 permit icmp any any time-exceeded access-list 101 permit icmp any any unreachable access-list 101 deny ip 10.0.0.0 0.255.255.255 any access-list 101 deny ip 172.16.0.0 0.15.255.255 any access-list 101 deny ip 192.168.0.0 0.0.255.255 any access-list 101 deny ip 127.0.0.0 0.255.255.255 any access-list 101 deny ip host 255.255.255.255 any access-list 101 deny ip host 0.0.0.0 any access-list 101 deny ip any any access-list 102 remark auto generated by SDM firewall configuration access-list 102 remark SDM_ACL Category=1 access-list 102 deny ip host 255.255.255.255 any access-list 102 deny ip 127.0.0.0 0.255.255.255 any access-list 102 permit ip any any access-list 103 remark auto generated by SDM firewall configuration access-list 103 remark SDM_ACL Category=1 access-list 103 deny ip 192.168.0.0 0.0.0.255 any access-list 103 permit icmp any any echo-reply access-list 103 permit icmp any any time-exceeded access-list 103 permit icmp any any unreachable access-list 103 deny ip 10.0.0.0 0.255.255.255 any access-list 103 deny ip 172.16.0.0 0.15.255.255 any access-list 103 deny ip 192.168.0.0 0.0.255.255 any access-list 103 deny ip 127.0.0.0 0.255.255.255 any access-list 103 deny ip host 255.255.255.255 any access-list 103 deny ip host 0.0.0.0 any access-list 103 deny ip any any log dialer-list 1 protocol ip permit no cdp run ! control-plane ! bridge 1 protocol ieee bridge 1 route ip banner login ^CAuthorized access only! Disconnect IMMEDIATELY if you are not an authorized user!^C ! line con 0 login local no modem enable transport preferred all transport output all line aux 0 transport preferred all transport output all line vty 0 4 privilege level 15 login local transport preferred all transport input telnet ssh transport output all ! scheduler max-task-time 5000 scheduler allocate 4000 1000 scheduler interval 500 end "Merv" wrote in message news: snipped-for-privacy@y43g2000cwc.googlegroups.com...
try:
int Vlan1 no ip address no ip nat inside exit
int bvi 1 ip address 192.168.0.109 255.255.255.0 ip access-group 102 in ip nat inside exit
