Cisco 871 router and WEP WPA-PSK
Nov 28, 2005 0 Replies
I am trying to configure a Cisco 871 integrated services router to use both WEP and WPA-PSK. The issue I am having is that WPA-PSK is not working. I am using a Linksys WPC54G pc card on a laptop. I've tried configuring the laptop using the Linksys configuration program and XP WZC and they both don't connect. Here is my config. Is there something I am missing? VLAN is being used for internal clients connecting to the internal network. VLAN 50 is being used for wifi guests, i.e. consultants etc, that need internet access. Once I get the two wVLANs running I will be using access lists to block access from the guest vlan.
Thanks
Current configuration : 2348 bytes ! version 12.3 no service pad service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname router ! boot-start-marker boot-end-marker ! ! username routeradmin no aaa new-model ip subnet-zero ip cef ip dhcp excluded-address 192.168.50.1 192.168.50.49 ip dhcp excluded-address 192.168.50.71 192.168.50.254 ! ip dhcp pool WiFiGuests import all network 192.168.50.0 255.255.255.0 default-router 192.168.50.1 ! ! ip domain name domain.com no ftp-server write-enable ! ! ! ! ! bridge irb ! ! interface FastEthernet0 no ip address duplex full speed 100 ! interface FastEthernet1 no ip address shutdown ! interface FastEthernet2 no ip address shutdown ! interface FastEthernet3 no ip address shutdown ! interface FastEthernet4 no ip address shutdown duplex auto speed auto ! interface Dot11Radio0 no ip address ! encryption mode ciphers tkip wep128 ! encryption vlan 50 key 1 size 128bit 0 21586656793557343746364B57 transmit-key encryption vlan 50 mode wep mandatory ! encryption vlan 1 mode ciphers tkip ! ssid wifi-wpapsk vlan 1 authentication open authentication key-management wpa wpa-psk ascii 0 wpapskpassword ! ssid wifi-wep vlan 50 authentication open ! speed basic-1.0 basic-2.0 basic-5.5 6.0 9.0 basic-11.0 12.0 18.0 24.0
36.0 48.0 54.0 station-role root ! interface Dot11Radio0.1 encapsulation dot1Q 1 native bridge-group 1 bridge-group 1 subscriber-loop-control bridge-group 1 spanning-disabled bridge-group 1 block-unknown-source no bridge-group 1 source-learning no bridge-group 1 unicast-flooding ! interface Dot11Radio0.50 encapsulation dot1Q 50 ip address 192.168.50.1 255.255.255.0 ! interface Vlan1 no ip address bridge-group 1 ! interface BVI1 ip address 10.10.50.1 255.255.255.0 ! ip classless ! no ip http server ip http authentication local ip http secure-server ! ! control-plane ! bridge 1 protocol ieee bridge 1 route ip ! line con 0 privilege level 15 login local no modem enable transport preferred all transport output all line aux 0 transport preferred all transport output all line vty 0 4 privilege level 15 login local transport preferred all transport input all transport output all ! scheduler max-task-time 5000 end
