Cisco 836 and VPN
Dec 26, 2005 7 Replies
Jump to replies (7)
Cisco 836 and VPN open original image
Hello,
I am using a Cisco 836 ADSL router and would like it to be a VPN Server allowing people to connect with a VPN client. I read about that Cisco Easy VPN Remote software which should be part of the IOS on the Cisco
836 but I cannot find the client software which I can install on Windows to connect to the VPN Server. First is this scenario possible ? Then where do I find the software if there is any ?
Many thanks Regards
syn_NOSPAM_uw schrieb:
Yes.
Depends on what you configure.
Standard IPsec is available with Windows 2000 or Windows XP or many other O/Ses.
With the Cisco VPN Client you can push allmost all configuration from the VPN concentrator to the client.
Without a PLUS IOS the encryption is only performed through software in the router's CPU. Throughput will be limited to less than 120kB/s using AES or less than 80kB/s using 3DES.
You can also configure PPTP as a convienient alternativ if security is not a real concern. All you need comes with Windows.
First, many thanks for your quick answer!
And is this Cisco VPN client free to download ?
I think I will go for the PPTP variant, unfortunately I didn't find any references of PPTP in the Cisco 836 documentation PDF:
Cisco 826, 827, 828, 831, 836, and 837 and Cisco SOHO 76, 77, 78, 91, 96, and 97 Routers Software Configuration Guide
which I downloaded :( Do you maybe have any pointers how I can configure a PPTP server on my Cisco 836 router ? Or maybe even a config example ?
Thanks in advance Regards
Consider asking Google with "cisco ios pptp".
How to configure Cisco Router for MS VPN clients (PPTP with MPPE):
I'm running Cisco EasyVPN Server and PPTP/L2TP Server both on Cisco router so feel free to ask me if something bothering you and I'll try to help 'ya..
B.R. Igor
Hi Igor, many thanks for your answer and the documentation it helped pretty much! The only thing I am not sure about is how to configure now PPTP login user accounts. I used the following account to create a user:
username vpnuser password 0 testpw
Unfortunately, authentication doesn't work as you can see here in the debug output:
... Dec 27 11:16:46: ppp14 LCP: I CONFACK [ACKsent] id 2 len 15 Dec 27 11:16:46: ppp14 LCP: AuthProto MS-CHAP-V2 (0x0305C22381) Dec 27 11:16:46: ppp14 LCP: MagicNumber 0x176CAE19 (0x0506176CAE19) Dec 27 11:16:46: ppp14 LCP: State is Open Dec 27 11:16:46: ppp14 PPP: Phase is AUTHENTICATING, by this end Dec 27 11:16:46: ppp14 MS-CHAP-V2: O CHALLENGE id 1 len 26 from "rtr" Dec 27 11:16:47: ppp14 MS-CHAP-V2: I RESPONSE id 1 len 59 from "vpnuser" Dec 27 11:16:47: ppp14 PPP: Phase is FORWARDING, Attempting Forward Dec 27 11:16:47: ppp14 PPP: Phase is AUTHENTICATING, Unauthenticated User Dec 27 11:16:47: ppp14 PPP: Sent MSCHAP_V2 LOGIN Request Dec 27 11:16:47: ppp14 PPP: Received LOGIN Response FAIL Dec 27 11:16:47: ppp14 MS-CHAP-V2: O FAILURE id 1 len 13 msg is "E=691 R=0" Dec 27 11:16:47: ppp14 PPP: Sending Acct Event[Down] id[16] Dec 27 11:16:47: ppp14 PPP: Phase is TERMINATING Dec 27 11:16:47: ppp14 LCP: O TERMREQ [Open] id 3 len 4 Dec 27 11:16:47: ppp14 LCP: State is Closed Dec 27 11:16:47: ppp14 PPP: Phase is DOWN Dec 27 11:16:47: ppp14 PPP: Phase is TERMINATING
Do you have any ideas what's wrong here ?
Thanks Regards
Can you post your pptp config? This+debug output you just posted can help me to troubleshoot this issue...
B.R. Igor
Thanks Igor, I have found the problem: I had to activate AAA.
Regards
