Cisco 2507 Transreceiver
Nov 10, 2007 2 Replies
Cisco 2507 Transreceiver open original image
I have a Cisco 2507 router and need to connect the serial port (DB-60) to the lab network (RJ-45). Does anyone know the product or transceiver device to make this work? Thanks
Scott,
DB-60 connector is SERIAL interface, you cannot connect it to Ethernet port. You may, depending on cable connected, use the interface as V.35, RS-232, etc., but not Ethernet. Cisco 2507 router (if it's what you have), has
16-ports integrated Ethernet hub, but I believe logically they all appear as one Ethernet interface.
Good luck,
Mike CCNP, CCDP, CCSP, Cisco Voice, MCSE W2K, MCSE+I, Security+, etc. CCIE R&S (in progress), CCIE Voice (in progress)
------ Headset Adapters for Cisco IP Phones
Another Cisco 250x router with a DCE-DTE DB60 cable between the two will do it..
