Change E1 card to T1 card possible on AS5350?
May 05, 2005 1 Replies
Hello all:
I have an AS5350, with two E1/PRI Ports:
cisco AS5350 (R7K) processor (revision T) with 131072K/65536K bytes of memory. Processor board ID JAE07170MY3 R7000 CPU at 250Mhz, Implementation 39, Rev 1.0, 256KB L2, 2048KB L3 Cache Last reset from power-on Channelized E1, Version 1.0. Bridging software. X.25 software, Version 3.0.0. SuperLAT software (copyright 1990 by Meridian Technology Corp). Primary Rate ISDN software, Version 1.1. Manufacture Cookie Info: EEPROM Type 0x0001, EEPROM Version 0x01, Board ID 0x32, Board Hardware Version 3.34, Item Number 800-5171-02, Board Revision C0, Serial Number JAE07170MY3, PLD/ISP Version 2.2, Manufacture Date 25-Apr-2003. Processor 0x14, MAC Address 0x0C30821B7A Backplane HW Revision 1.0, Flash Type 5V
2 FastEthernet/IEEE 802.3 interface(s)
2 Serial network interface(s)
60 terminal line(s)
2 Channelized E1/PRI port(s)
512K bytes of non-volatile configuration memory.
32768K bytes of processor board System flash (Read/Write)
8192K bytes of processor board Boot flash (Read/Write)
Is it possible to some how flash the firmwares on those E1 ports and make them T1/PRI port?
Thank you,
John
The DFC trunk cards are not field switchable between E1 and T1, sorry.
Aaron
