AS5400 thinks it is an as5350
Nov 13, 2005 2 Replies
Hi, I have an as5400, and was having problems getting my np60 and 2E1 boards being recognized. It seems that the as5400 thinks it is an as5350, and only recognizes boards inserted into the bottom 3 slots. Is this a setting somewhere, or did the supplier install the wrong IOS?
Thanks for any ideas. Richard.
sh ver: Cisco IOS Software, 5350 Software (C5350-JS-M), Version 12.4(1), RELEASE SOFTWARE (fc3) Technical Support:
(c) 1986-2005 by Cisco Systems, Inc. Compiled Fri 29-Apr-05 17:08 by hqluong
ROM: System Bootstrap, Version 12.2(1r)1, RELEASE SOFTWARE (fc1) BOOTLDR: 5400 Software (C5400-BOOT-M), Version 12.2(2)XB2, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
net2 uptime is 2 hours, 36 minutes System returned to ROM by reload at 19:34:11 UTC Sun Nov 13 2005 System restarted at 19:35:00 UTC Sun Nov 13 2005 System image file is "flash:c5400-js-mz.124-1.bin"
Cisco AS5400 (R7K) processor (revision T) with 262144K/131072K bytes of memory. Processor board ID JAE090658WZ R7000 CPU at 250MHz, Implementation 39, Rev 1.0, 256KB L2, 2048KB L3 Cache Last reset from IOS reload Manufacture Cookie Info: EEPROM Type 0x0001, EEPROM Version 0x01, Board ID 0x31, Board Hardware Version 3.34, Item Number 800-5171-02, Board Revision C0, Serial Number JAE090658WZ, PLD/ISP Version 2.2, Manufacture Date 2-Feb-2005. Processor 0x14, MAC Address 0012.801c.6894 Backplane HW Revision 1.0, Flash Type 5V
2 FastEthernet interfaces
76 Serial interfaces
60 terminal lines
4 Channelized E1/PRI ports
512K bytes of NVRAM.
32768K bytes of processor board System flash (Read/Write)
16384K bytes of processor board Boot flash (Read/Write)
Configuration register is 0x2102
My guess is simply that your file "c5400-js-mz.124-1.bin" is actually a 5350 image not a 5400 image, and if you load a real 5400 image, this box will think it's a 5400.
Funnily enough, I just now checked a 5400 in our lab, and someone had loaded a 5350 image on it, and it looks and behaves just like yours. Guess I'd better fix it ...
Cheers,
Aaron
Hi, Yes, you're right. I installed another IOS, and now it shows all 7 ports as usual. Strangely the image that was on it had 5400 in its name.
Richard.
