6509 Booting in rommon
May 01, 2005 9 Replies
Jump to replies (9)
I asked this a few months back but got called off to another site. So here is some more information. The unit always goes into rommon mode when it is powered down and back up. Here is what is going on.
System Bootstrap, Version 6.1(3) Copyright (c) 1994-2000 by cisco Systems, Inc.
Testing lower main memory - data equals address Testing lower main memory - checkerboard Testing lower main memory - inverse checkerboard Clearing lower 16K memory for cache initialization Clearing bss Reading monitor variables from NVRAM Warning: Rommon NVRAM area is corrupted. Initialize the area to default values
Enabling interrupts Initializing TLB Initializing cache Initializing required TLB entries Initializing main memory Sizing NVRAM Initializing PCMCIA controller Exiting init c6k_sup2 processor with 131072 Kbytes of main memory
rommon 1 > sh mod
monitor: command "sh" not found rommon 2 > boot
Self decompressing the image : ############################################################################################################################################]
Restricted Rights Legend
Use, duplication, or disclosure by the Government is subject to restrictions as set forth in subparagraph (c) of the Commercial Computer Software - Restricted Rights clause at FAR sec. 52.227-19 and subparagraph (c) (1) (ii) of the Rights in Technical Data and Computer Software clause at DFARS sec. 252.227-7013.
cisco Systems, Inc. 170 West Tasman Drive San Jose, California 95134-1706
Cisco Internetwork Operating System Software IOS (tm) c6sup2_sp Software (c6sup2_sp-SP-M), Version 12.1(20)E, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1) TAC Support:
(c) 1986-2003 by cisco Systems, Inc. Compiled Sat 25-Oct-03 09:55 by hqluong Image text-base: 0x40020F90, data-base: 0x40978000
00:00:02: %PFREDUN-6-ACTIVE: Initializing as ACTIVE processor
00:00:03: %OIR-6-CONSOLE: Changing console ownership to route processor
System Bootstrap, Version 12.1(3r)E2, RELEASE SOFTWARE (fc1) Copyright (c) 2000 by cisco Systems, Inc. Cat6k-MSFC2 platform with 131072 Kbytes of main memory
Download Start !!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!!! Download Completed! Booting the image. Self decompressing the image : ############################################################################################################################################]
Cisco Internetwork Operating System Software IOS (tm) c6sup2_rp Software (c6sup2_rp-PS-M), Version 12.1(20)E, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1) TAC Support:
(c) 1986-2003 by cisco Systems, Inc. Compiled Sat 25-Oct-03 09:18 by hqluong Image text-base: 0x40008F90, data-base: 0x4184E000
cisco WS-C6509 (R7000) processor (revision 1.0) with 112640K/18432K bytes of memory. Processor board ID SCA0318003V R7000 CPU at 300Mhz, Implementation 39, Rev 2.1, 256KB L2, 1024KB L3 Cache Last reset from power-on X.25 software, Version 3.0.0. Bridging software.
1 Virtual Ethernet/IEEE 802.3 interface(s)
48 FastEthernet/IEEE 802.3 interface(s)
2 Gigabit Ethernet/IEEE 802.3 interface(s)
381K bytes of non-volatile configuration memory.
16384K bytes of Flash internal SIMM (Sector size 512K). %Error opening tftp://255.255.255.255/network-confg (Socket error) %Error opening tftp://255.255.255.255/cisconet.cfg (Socket error) SETUP: new interface Vlan1 placed in "shutdown" state SETUP: new interface GigabitEthernet1/1 placed in "shutdown" state SETUP: new interface GigabitEthernet1/2 placed in "shutdown" state SETUP: new interface FastEthernet4/1 placed in "shutdown" state SETUP: new interface FastEthernet4/2 placed in "shutdown" state SETUP: new interface FastEthernet4/3 placed in "shutdown" state SETUP: new interface FastEthernet4/4 placed in "shutdown" state SETUP: new interface FastEthernet4/5 placed in "shutdown" state SETUP: new interface FastEthernet4/6 placed in "shutdown" state SETUP: new interface FastEthernet4/7 placed in "shutdown" state SETUP: new interface FastEthernet4/8 placed in "shutdown" state SETUP: new interface FastEthernet4/9 placed in "shutdown" state SETUP: new interface FastEthernet4/10 placed in "shutdown" state SETUP: new interface FastEthernet4/11 placed in "shutdown" state SETUP: new interface FastEthernet4/12 placed in "shutdown" state SETUP: new interface FastEthernet4/13 placed in "shutdown" state SETUP: new interface FastEthernet4/14 placed in "shutdown" state SETUP: new interface FastEthernet4/15 placed in "shutdown" state SETUP: new interface FastEthernet4/16 placed in "shutdown" state SETUP: new interface FastEthernet4/17 placed in "shutdown" state SETUP: new interface FastEthernet4/18 placed in "shutdown" state SETUP: new interface FastEthernet4/19 placed in "shutdown" state SETUP: new interface FastEthernet4/20 placed in "shutdown" state SETUP: new interface FastEthernet4/21 placed in "shutdown" state SETUP: new interface FastEthernet4/22 placed in "shutdown" state SETUP: new interface FastEthernet4/23 placed in "shutdown" state SETUP: new interface FastEthernet4/24 placed in "shutdown" state SETUP: new interface FastEthernet4/25 placed in "shutdown" state SETUP: new interface FastEthernet4/26 placed in "shutdown" state SETUP: new interface FastEthernet4/27 placed in "shutdown" state SETUP: new interface FastEthernet4/28 placed in "shutdown" state SETUP: new interface FastEthernet4/29 placed in "shutdown" state SETUP: new interface FastEthernet4/30 placed in "shutdown" state SETUP: new interface FastEthernet4/31 placed in "shutdown" state SETUP: new interface FastEthernet4/32 placed in "shutdown" state SETUP: new interface FastEthernet4/33 placed in "shutdown" state SETUP: new interface FastEthernet4/34 placed in "shutdown" state SETUP: new interface FastEthernet4/35 placed in "shutdown" state SETUP: new interface FastEthernet4/36 placed in "shutdown" state SETUP: new interface FastEthernet4/37 placed in "shutdown" state SETUP: new interface FastEthernet4/38 placed in "shutdown" state SETUP: new interface FastEthernet4/39 placed in "shutdown" state SETUP: new interface FastEthernet4/40 placed in "shutdown" state SETUP: new interface FastEthernet4/41 placed in "shutdown" state SETUP: new interface FastEthernet4/42 placed in "shutdown" state SETUP: new interface FastEthernet4/43 placed in "shutdown" state SETUP: new interface FastEthernet4/44 placed in "shutdown" state SETUP: new interface FastEthernet4/45 placed in "shutdown" state SETUP: new interface FastEthernet4/46 placed in "shutdown" state SETUP: new interface FastEthernet4/47 placed in "shutdown" state SETUP: new interface FastEthernet4/48 placed in "shutdown" state
Press RETURN to get started!
00:00:33: RP: Currently running ROMMON from S (Gold) region
00:01:02: %SYS-5-RESTART: System restarted -- Cisco Internetwork Operating System Software IOS (tm) c6sup2_rp Software (c6sup2_rp-PS-M), Version 12.1(20)E, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1) TAC Support:
00:00:37: SP: SP: Currently running ROMMON from S (Gold) region
00:00:39: %C6K_PLATFORM-SP-4-CONFREG_BREAK_ENABLED: The default factory setting for config register is 0x2102.It is advisable to retain 1 in
0x2102 as it prevents returnin.
00:01:02: %SNMP-5-COLDSTART: SNMP agent on host Router is undergoing a cold start
00:01:02: %SYS-6-BOOTTIME: Time taken to reboot after reload = 445 seconds
00:01:01: %SYS-SP-5-RESTART: System restarted -- Cisco Internetwork Operating System Software IOS (tm) c6sup2_sp Software (c6sup2_sp-SP-M), Version 12.1(20)E, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1) TAC Support:
00:01:03: %OIR-SP-6-INSPS: Power supply inserted in slot 1
00:01:03: %OIR-SP-6-INSPS: Power supply inserted in slot 2
00:01:03: %C6KPWR-SP-4-PSOK: power supply 2 turned on.
00:01:05: %C6KENV-SP-4-PSFANFAILED: the fan in power supply 1 has failed
00:01:16: %DIAG-SP-6-RUN_MINIMUM: Module 1: Running Minimum Online Diagnostics...
00:01:20: %DIAG-SP-6-DIAG_OK: Module 1: Passed Online Diagnostics
00:01:20: %OIR-SP-6-INSCARD: Card inserted in slot 1, interfaces are now online
00:01:35: %DIAG-SP-6-RUN_MINIMUM: Module 4: Running Minimum Online Diagnostics...
00:01:44: %DIAG-SP-6-DIAG_OK: Module 4: Passed Online Diagnostics
00:01:44: %OIR-SP-6-INSCARD: Card inserted in slot 4, interfaces are now online Router>sh mod Mod Ports Card Type Model Serial No.
----------- 1 2 Catalyst 6000 supervisor 2 (Active) WS-X6K-SUP2-2GE SAD050707ZU 4 48 48 port 10/100 mb RJ45 WS-X6348-RJ-45 SAL05084X6T
Mod MAC addresses Hw Fw Sw Status
------- 1 0004.c0f8.9e76 to 0004.c0f8.9e77 2.2 6.1(3) 12.1(20)E Ok 4 0004.de61.f760 to 0004.de61.f78f 2.0 5.4(2) 8.2(0.58)TFW Ok
Mod Sub-Module Model Serial Hw Status
------- 1 Policy Feature Card 2 WS-F6K-PFC2 SAD05080T6L 1.3 Ok 1 Cat6k MSFC 2 daughterboard WS-F6K-MSFC2 SAD05080KHG 1.2 Ok
Mod Online Diag Status
--- ------------------- 1 Pass 4 Pass Router>
That is not for the same card as what I have installed. Though it could be the same issue a bad crystal. I just want to rule out everything else.
"JC" wrote in news:1114995036.191731.74690 @f14g2000cwb.googlegroups.com:
We had seen this a couple of times. I assume you're using native, not hybrid. Once the thing is booted, do:
sho ver to see the RP config register.
remote command switch sho ver to see the SP config register.
If they don't match, set them so they do match and reboot (at least, that is the problem that we had, the cfg regs were not synced).
hope this helps,
c
Pls post the show version... The default config-register value should be 0x2102... If iti s anything else. then this may be the reason.. or else...ur NVRAM might be corrupted for which u may have to contact cisco TAC......
Cheers, Naveen B
Have you set the configuration register to the normal value of 0x2102? This would normally regain the correct boot sequence.
As you are using hybrid, there are two config-registers, one on the SUP and one on the MSFC. Both should be 0x2102. The one on the MSFC you see easily with "sh ver", the other on the SUP you can see with "remote command switch show version"
Simon
"JC" schrieb im Newsbeitrag news: snipped-for-privacy@f14g2000cwb.googlegroups.com...
Router#remote command switch show version Cisco Internetwork Operating System Software IOS (tm) c6sup2_sp Software (c6sup2_sp-SP-M), Version 12.1(20)E, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1) TAC Support:
ROM: System Bootstrap, Version 6.1(3) BOOTLDR: c6sup2_sp Software (c6sup2_sp-SP-M), Version 12.1(20)E, EARLY DEPLOYMENT RELEASE SOFTWARE (fc1)
Router uptime is 2 minutes Time since Router switched to active is 2 minutes System returned to ROM by error - a Software forced crash, PC
0x401252BC at 13:12:34 UTC Mon May 2 2005 System image file is "bootflash:c6sup22-ps-mz.121-20.E.bin"
cisco WS-C6509 (R7000) processor (revision 1.0) with 112640K/18432K bytes of memory. Processor board ID SCA0318003V R7000 CPU at 250Mhz, Implementation 39, Rev 2.1, 256KB L2, 1024KB L3 Cache Last reset from power-on X.25 software, Version 3.0.0.
48 FastEthernet/IEEE 802.3 interface(s) 2 Gigabit Ethernet/IEEE 802.3 interface(s) 381K bytes of non-volatile configuration memory.
32768K bytes of Flash internal SIMM (Sector size 512K). Configuration register is 0x8000
It has gotten to the point where my boss and I have decided to hire someone to look into this. So if any of you are interested contact me at snipped-for-privacy@gmail.com.
