Calls to an extension result in fast-busy when rolling to Unity Express voicemail
Oct 28, 2008 1 Replies
CME/CUE newbie warning...
I'm working in a test environment. I have a Cisco 2691 running C2691- ADVIPSERVICESK9-M, Version 12.4(21) and CME 3.4, with an AIM module running CUE 3.2.2. I have two phones registered, a 7940 and a 7960.
I can call from one phone to the other. I can also call from a phone to the voice-mail system, where I've successfully setup two voice mailboxes, and recorded my greetings for two test users. The test environment is completely isolated, so there's no PSTN connectivity to worry with at this point.
When I call from one phone to the other and wait for the voice-mail system to kick in, I get a fast-busy signal. The Cisco docs I've found suggest this can be caused by an incorrect codec, but I've double-checked my settings there and found nothing wrong.
If anyone has any ideas on this, thanks in advance.
Since there's nothing sacred on either the router or the AIM, here are the configs:
---------- ROUTER ----------
Current configuration : 4850 bytes ! ! No configuration change since last restart ! version 12.4 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname CME-Test-Router ! boot-start-marker boot system flash c2691-advipservicesk9-mz.124-21.bin boot-end-marker ! enable secret 5 $1$7otI$hiAt2p2G4AzoZoRtm.UWm. enable password none ! no aaa new-model ip cef ! ! no ip dhcp use vrf connected ip dhcp excluded-address 192.168.1.1 192.168.1.10 ip dhcp excluded-address 192.168.10.1 192.168.10.10 ip dhcp excluded-address 192.168.11.1 192.168.11.10 ! ip dhcp pool WAN network 192.168.1.0 255.255.255.0 default-router 192.168.1.1 ! ip dhcp pool DATA network 192.168.10.0 255.255.255.0 default-router 192.168.10.1 option 150 ip 192.168.10.1 domain-name domain.test dns-server 192.168.10.1 ! ip dhcp pool VOICE network 192.168.11.0 255.255.255.0 default-router 192.168.11.1 option 150 ip 192.168.11.1 domain-name domain.test dns-server 192.168.10.1 ! ! ip host ns.manh.com 192.168.1.1 ip host CME-Test-Router.domain.test 192.168.10.1 ip host CME-Test-Switch.domain.test 192.168.10.2 ip host CME-Test-Router-VM.domain.test 192.168.11.3 ip auth-proxy max-nodata-conns 3 ip admission max-nodata-conns 3 ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! ! interface FastEthernet0/0 no ip address duplex auto speed auto no mop enabled ! interface FastEthernet0/0.1 encapsulation dot1Q 1 native ip address 192.168.1.1 255.255.255.0 no cdp enable ! interface Service-Engine0/0 ip unnumbered FastEthernet0/1.2 service-module ip address 192.168.11.3 255.255.255.0 service-module ip default-gateway 192.168.11.1 ! interface FastEthernet0/1 no ip address speed 100 full-duplex ! interface FastEthernet0/1.1 encapsulation dot1Q 1 native ip address 192.168.10.1 255.255.255.0 ! interface FastEthernet0/1.2 encapsulation dot1Q 2 ip address 192.168.11.1 255.255.255.0 ! ip forward-protocol nd ip route 192.168.11.3 255.255.255.255 Service-Engine0/0 ! ! ip http server no ip http secure-server ! ! ! ! tftp-server flash:P00403020214.bin tftp-server flash:P00307020200.bin tftp-server flash:P00307020200.loads tftp-server flash:P00307020200.sb2 tftp-server flash:P00307020200.sbn tftp-server flash:P003-07-4-00.bin tftp-server flash:P003-07-4-00.sbn ! control-plane ! ! ! ! ! ! ! dial-peer voice 1999 voip destination-pattern 1999 session protocol sipv2 session target ipv4:192.168.11.3 incoming called-number . dtmf-relay sip-notify codec g711ulaw no vad ! dial-peer voice 1998 voip destination-pattern 1998 session protocol sipv2 session target ipv4:192.168.11.3 incoming called-number . dtmf-relay sip-notify codec g711ulaw no vad ! dial-peer voice 1997 voip destination-pattern 1997 session protocol sipv2 session target ipv4:192.168.11.3 incoming called-number . dtmf-relay sip-notify codec g711ulaw no vad ! ! ! ! telephony-service load 7960-7940 P00307020200 max-ephones 10 max-dn 10 ip source-address 192.168.11.1 port 2000 auto assign 1 to 10 url services http://192.168.11.3/voiceview/common/login.do url authentication http://192.168.11.3/voiceview/authentication/authenticate.do create cnf-files version-stamp 7960 Oct 27 2008 05:25:07 dialplan-pattern 1 4045551... extension-length 4 voicemail 1999 max-conferences 4 gain -6 moh music-on-hold.au transfer-system full-consult ! ! ephone-dn 1 dual-line number 1000 call-forward busy 1999 call-forward noan 1999 timeout 18 ! ! ephone-dn 2 dual-line number 1001 call-forward busy 1999 call-forward noan 1999 timeout 18 ! ! ephone-dn 3 dual-line number 1002 call-forward busy 1999 call-forward noan 1999 timeout 18 ! ! ephone-dn 4 dual-line number 1003 call-forward busy 1999 call-forward noan 1999 timeout 18 ! ! ephone-dn 5 dual-line number 1004 call-forward busy 1999 call-forward noan 1999 timeout 18 ! ! ephone-dn 6 dual-line number 1005 call-forward busy 1999 call-forward noan 1999 timeout 18 ! ! ephone-dn 7 dual-line number 1006 call-forward busy 1999 call-forward noan 1999 timeout 18 ! ! ephone-dn 8 dual-line number 1007 call-forward busy 1999 call-forward noan 1999 timeout 18 ! ! ephone-dn 9 dual-line number 1008 call-forward busy 1999 call-forward noan 1999 timeout 18 ! ! ephone-dn 10 dual-line number 1009 call-forward busy 1999 call-forward noan 1999 timeout 18 ! ! ephone 1 mac-address 000D.284C.E9C0 type 7940 button 1:1 ! ! ! ephone 2 mac-address 0003.E363.0B90 type 7960 button 1:2 ! ! ! ephone 3 ! ! ! ephone 4 ! ! ! ephone 5 ! ! ! ephone 6 ! ! ! ephone 7 ! ! ! ephone 8 ! ! ! ephone 9 ! ! ! ephone 10 ! ! ! line con 0 line 26 no activation-character no exec transport preferred none transport input all transport output all line aux 0 line vty 0 4 password cisco login ! ntp master 1 ntp server 192.168.10.1 ! end
---------- AIM MODULE ----------
clock timezone America/New_York
hostname CME-Test-VM
ip domain-name domain.test
system language preferred "en_US"
ntp server 192.168.11.1 prefer
software download server url "ftp://127.0.0.1/ftp" credentials hidden "6u/dKTN/hsEuSAEfw40XlF2eFHnZfyUTSd8ZZNgd
+Y9J3xlk2B35j0nfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmPSd8ZZNgd
+Y9J3xlk2B35j0nfGWTYHfmP" site name local site-hostname 192.168.11.1 web credentials hidden "c9yem6kD1vJqrOHVxftjAknfGWTYHfmPSd8ZZNgd
+Y9J3xlk2B35j0nfGWTYHfmP" end site
groupname Administrators create groupname Broadcasters create
username admin create username uone create username utwo create username uone phonenumber "1000" username utwo phonenumber "1001"
groupname Administrators member admin groupname Administrators privilege ManagePrompts groupname Administrators privilege broadcast groupname Administrators privilege local-broadcast groupname Administrators privilege ManagePublicList groupname Administrators privilege ViewPrivateList groupname Administrators privilege vm-imap groupname Administrators privilege ViewHistoricalReports groupname Administrators privilege ViewRealTimeReports groupname Administrators privilege superuser groupname Broadcasters privilege broadcast
restriction msg-notification create restriction msg-notification min-digits 1 restriction msg-notification max-digits 30 restriction msg-notification dial-string preference 1 pattern * allowed
backup server url "ftp://127.0.0.1/ftp" credentials hidden "EWlTygcMhYmjazXhE/ VNXHCkplVV4KjescbDaLa4fl4WLSPFvv1rWUnfGWTYHfmPSd8ZZNgd
+Y9J3xlk2B35j0nfGWTYHfmPSd8ZZNgd+Y9J3xlk2B35j0nfGWTYHfmP"
calendar biz-schedule systemschedule open day 1 from 00:00 to 24:00 open day 2 from 00:00 to 24:00 open day 3 from 00:00 to 24:00 open day 4 from 00:00 to 24:00 open day 5 from 00:00 to 24:00 open day 6 from 00:00 to 24:00 open day 7 from 00:00 to 24:00 end schedule
ccn application autoattendant aa description "autoattendant" enabled maxsessions 6 script "aa.aef" parameter "busClosedPrompt" "AABusinessClosed.wav" parameter "holidayPrompt" "AAHolidayPrompt.wav" parameter "welcomePrompt" "AAWelcome.wav" parameter "disconnectAfterMenu" "false" parameter "dialByFirstName" "false" parameter "allowExternalTransfers" "false" parameter "MaxRetry" "3" parameter "dialByExtnAnytime" "false" parameter "busOpenPrompt" "AABusinessOpen.wav" parameter "businessSchedule" "systemschedule" parameter "dialByExtnAnytimeInputLength" "4" parameter "operExtn" "0" end application
ccn application ciscomwiapplication aa description "ciscomwiapplication" enabled maxsessions 6 script "setmwi.aef" parameter "CallControlGroupID" "0" parameter "strMWI_OFF_DN" "8001" parameter "strMWI_ON_DN" "8000" end application
ccn application msgnotification aa description "msgnotification" enabled maxsessions 6 script "msgnotify.aef" parameter "logoutUri" "http://localhost/voicemail/vxmlscripts/mbxLogout.jsp" parameter "DelayBeforeSendDTMF" "1" end application
ccn application promptmgmt aa description "promptmgmt" enabled maxsessions 1 script "promptmgmt.aef" end application
ccn application voicemail aa description "voicemail" enabled maxsessions 6 script "voicebrowser.aef" parameter "logoutUri" "http://localhost/voicemail/vxmlscripts/mbxLogout.jsp" parameter "uri" "http://localhost/voicemail/vxmlscripts/login.vxml" end application
ccn engine end engine
ccn reporting historical database local description "CME-Test-VM" end reporting
ccn subsystem sip gateway address "192.168.11.1" end subsystem
ccn trigger http urlname msgnotifytrg application "msgnotification" enabled maxsessions 2 end trigger
ccn trigger http urlname mwiapp application "ciscomwiapplication" enabled maxsessions 1 end trigger
ccn trigger sip phonenumber 1997 application "promptmgmt" enabled locale "en_US" maxsessions 1 end trigger
ccn trigger sip phonenumber 1998 application "autoattendant" enabled locale "en_US" maxsessions 6 end trigger
ccn trigger sip phonenumber 1999 application "voicemail" enabled maxsessions 6 end trigger
network location id "1" email domain domain.test end location
network local location id 1
security password lockout policy temp-lock security pin lockout policy temp-lock service phone-authentication end phone-authentication
service voiceview enable end voiceview
voicemail callerid voicemail broadcast recording time 300 voicemail default messagesize 30 voicemail notification restriction msg-notification voicemail mailbox owner "uone" size 120 description "uone mailbox" end mailbox
voicemail mailbox owner "utwo" size 120 description "utwo mailbox" end mailbox
end
---------- END OF CONFIGS ----------
I also have a 3500 switch, but there's no problem there so I'm skipping its config.
Everything's basically left at its default settings.
BTW, I noticed the bad DNS entry for the AIM and corrected it, but that didn't change anything.
