Help with IOS12.3d9 and a NI-2 PRI
Feb 06, 2006 1 Replies
Hey guys, normally I just lurk but I need some help from the collective mind share. First though sorry for posting more config then I have to but I'm not sure what is relavant
Before I list my problems I thought I should say that I _seem_ to have the phsyical ISDN link 2/3 setup properly. There are no errored seconds, slips, and the 'show isdn status' always show it second. I can make calls both ways and the audio sounds fine - however the unit isn't handling the calls quite the way I want
Incoming calls: In coming calls have audio that work, I can see the digits being passed to the first when a call is coming in and everything looks good. However the cisco doesn't really seem to be doing much with those digiits. It answers an incoming call to any number ( it seems) and just treats it like a normal FXO (I think, incoming line) and starts to match digits. How can I make it match the received digits off the dailplan ???????
I can make outgoing calls normally from the sip to PSTN side. However when I place incoming call to the Cisco it answers any number and gives me a dialtone, I put a destination that matches a SIP dial-peer it it connects the call (if it answers in the few seconds before it hangs up) and then terminates. After the config is also the Cisco 'debug isdn q921','debug isdn q931' output
My config I'l trying not to post the whole thing, so I'l only posting snippits
! interface Serial1:23 no ip address ip broadcast-address 0.0.0.0 no logging event link-status isdn switch-type primary-ni isdn protocol-emulate network isdn incoming-voice voice isdn T310 30000 no cdp enable ! ! ! ! dial-peer voice 999 pots max-conn 12 destination-pattern 999 port 1:23 ! dial-peer voice 3000 voip application session destination-pattern 30.. session protocol sipv2 session target ipv4:192.168.4.250 session transport udp dtmf-relay rtp-nte codec g711ulaw ! destination-pattern 9T port 1:23 !
debug output: Feb 6 23:45:02.459: ISDN Se1:23 Q931: CONNECT pd = 8 callref = 0x8004 Feb 6 23:45:02.503: ISDN Se1:23 Q921: Net RX RR sapi=0 tei=0 nr=0 Feb 6 23:45:05.155: ISDN Se1:23 Q921: Net RX RR sapi=0 tei=0 nr=1 Feb 6 23:45:05.175: ISDN Se1:23 Q921: Net TX -> INFO sapi=0 tei=0, ns=82 nr=1 Feb 6 23:45:05.175: ISDN Se1:23 Q931: RELEASE pd = 8 callref = 0x8004 Feb 6 23:45:05.199: ISDN Se1:23 Q921: Net RX RR sapi=0 tei=0 nr=2 Feb 6 23:45:05.215: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 1, ConnectionId 6 D0933AD 96A111DA 80C5DB3D A95613E, SetupTime 23:45:02.411 UTC Mon Feb 6
2006, Pe erAddress 999, PeerSubAddress , DisconnectCause 10 , DisconnectText normal call clearing (16), ConnectTime 23:45:03.711 UTC Mon Feb 6 2006, DisconnectTime 23:4
5:05.185 UTC Mon Feb 6 2006, CallOrigin 2, ChargedUnits 0, InfoType 2, TransmitP ackets 74, TransmitBytes 11840, ReceivePackets 72, ReceiveBytes 11520 Feb 6 23:45:05.279: %VOIPAAA-5-VOIP_CALL_HISTORY: CallLegType 2, ConnectionId 6 D0933AD 96A111DA 80C5DB3D A95613E, SetupTime 23:45:03.569 UTC Mon Feb 6
2006, Pe erAddress 600, PeerSubAddress , DisconnectCause 10 , DisconnectText normal call clearing (16), ConnectTime 23:45:03.699 UTC Mon Feb 6 2006, DisconnectTime 23:4
5:05.269 UTC Mon Feb 6 2006, CallOrigin 1, ChargedUnits 0, InfoType 2, TransmitP ackets 72, TransmitBytes 11520, ReceivePackets 79, ReceiveBytes 12640
