BRI Spoofing
Sep 19, 2005 3 Replies
Jump to replies (3)
Hi Guys
The status for my BRI card reads up/up (spoofing). How can correct this problem?
What problem?
Its up as long as a BRI is plugged into it. It may or not be up on layer-3 but thats when you bind a dialer interface to it to dial out over the BRI, and the status of the dialer interface should track your layer-3 status.
In article , Doug McIntyre wrote: : snipped-for-privacy@gmail.com writes: :>The status for my BRI card reads up/up (spoofing). :>How can correct this problem?
:What problem?
I think he means the "problem" that the interface says "spoofing".
[I don't know anything about BRI, so I don't know when "spoofing" is normal.]
There is no 'problem.'
This is normal for a dial interface like BRI.
The layer 2 protocol does not have a peer to communicate with when there is no phone call / connection established. Normally, the absence of a layer 2 peer would cause the protocol to go 'down.'
Here, "spoofing" infers that they layer 2 protocol is being 'fooled' internally to think that there is a connection to a peer when in fact there is no connection, because there hasn't been any phone call placed yet.
When you establish the connection, the 'spoofing' should go away because a real layer 2 peer will now be available to keep the protocol 'up.'
HTH
-ja
