ADSL WIC 2800 Series
Nov 17, 2006 1 Replies
I've just got a 2800 series router and am planning on putting in multiple ADSL 1 WIC cards , problems i've got is it won't accept the int atm command
Router (config)#int atm0/0/0 ^ % Invalid input detected at '^' marker.
i think it's an IOS issue but reading some newsgroups it says this release should work
Cisco IOS Software, 2800 Software (C2800NM-IPBASE-M), Version 12.4(3f), RELEASE SOFTWARE (fc3) Technical Support:
(c) 1986-2006 by Cisco Systems, Inc. Compiled Fri 18-Aug-06 18:47 by alnguyen
ROM: System Bootstrap, Version 12.4(1r) [hqluong 1r], RELEASE SOFTWARE (fc1)
MABMK uptime is 13 minutes System returned to ROM by power-on System image file is "flash:c2800nm-ipbase-mz.124-3f.bin"
Can anyone confirm ?
You have IPBASE.
You need ADVANCED or Enterprise for ADSL.
Check out the Feature Navigator (cisco.com/go/fn) (signup for a free account to access if you need one).
