Multilink Frame Relay - which IOS supports it
Feb 27, 2008 4 Replies
Jump to replies (4)
I need to set MFR on a router but the two IOS version I tried don't support the commands. I tried IP 12.3(23) and IP PLUS 12.2(29b).
Does anyone know which IOS version I can use?
Thanks for the update. My problem is that I'm using a 2621 that doesn't support 12.4. Do you where I can get the (what should be a simple) answer to this question?
Try this:
aof#sh ver Cisco Internetwork Operating System Software IOS (tm) C2600 Software (C2600-J1S3-M), Version 12.3(17a), RELEASE SOFTWARE (fc2) Technical Support:
(c) 1986-2005 by cisco Systems, Inc. Compiled Mon 12-Dec-05 14:12 by evmiller Image text-base: 0x80008098, data-base: 0x81A33618 ROM: System Bootstrap, Version 11.3(2)XA4, RELEASE SOFTWARE (fc1) ROM: C2600 Software (C2600-J1S3-M), Version 12.3(17a), RELEASE SOFTWARE (fc2)
That router is currently configured for Multilink PPP....
Feature Navigator knows. :)
(But then again, you are using a router that has been announced end-of-life over 5 years now, and the official end-of-support is in a few months).
Looks like you need IP+ and up in 12.3(x) or 12.2(x)T. Looks like there is a few images in there that can deal with 16M Flash, but you'll need the max 64M of DRAM to make it work.
