7507/PSTN
Feb 10, 2006 3 Replies
Jump to replies (3)
Hi!
Can I use a 7507 with PA-2CE1 to connect to PSTN in order to act as a gateway for an asterisk box.
Thanks, Christian
No, PA-2CE1 is no voice interface and so has no dsp nore will the router accept any voice commands related to that interface.
Are there any voice interfaces for that router?
Thanks, Christian
Actually I don´t know by heart. I would also have to look at the product list. I do think so, because if you have VIP-boards you can user interfaces from cisco7200 routers but they are usually very expensive. So the mor cost-effective way is probably to buy a cheaper voice enabled router.
