7206 VXR poor performance in LAN
Mar 25, 2005 2 Replies
Hi all
recently i brought 7206VXR, so before deploying in network i feel like testing the Fastethernet speeds
I have 7206vxr/npe300(256mb ram), 4 FE installed
i configured fastether 2/0 and 2/1 and the network connected like below my test setup
my laptop ----(cross cable)--fe2/1--fe2/0--Swtich(5500)--FTPSERVER
ftp server IP 192.168.100.1 FE 2/0 ip address 192.168.100.2 gw 192.168.100.1 FE 2/1 ip address 192.168.200.1 My PC address 192.168.200.254 gw 192.168.200.1
--- 5500 configured just switch mode, no special config.. and its working past year
when i transfer the files from PC to ftp server iam able to send files 100kbps when i try to download files from ftp server to my laptop iam able to download 1.2 MB
anther thing i noticed here is
when i configure my PC with IP
192.168.100.3 and connect my PC directly to 5500 swtich port
from same FTP server iam able to download 6.0MB and upload 4MB
so iam now in confusion what wrong iam doing with my 7200 config.. or something wrong with my config
iam posting config down
Current configuration : 1816 bytes ! version 12.2 service nagle no service pad service tcp-keepalives-in service tcp-keepalives-out service timestamps debug uptime service timestamps log uptime service password-encryption ! hostname gateway2005 ! enable secret 5 xxxxxxxxxxxxxxxxxxxxxxxx enable password 7 xxxxxxxxxxxxxxxxxxxxxxxxx ! ip subnet-zero ip cef ! ! no ip bootp server call rsvp-sync ! interface FastEthernet2/0 ip address 192.168.100.2 255.255.255.0 no ip redirects no ip unreachables no ip proxy-arp no ip route-cache cef duplex full no cdp enable no mop enabled ! interface FastEthernet2/1 ip address 192.168.200.1 255.255.255.0 no ip redirects no ip unreachables no ip proxy-arp no ip route-cache cef duplex full no cdp enable no mop enabled ! interface FastEthernet3/0 no ip address shutdown duplex half ! interface FastEthernet3/1 no ip address duplex half ! ip classless ip route 0.0.0.0 0.0.0.0 192.168.100.1 no ip http server ! access-list 4 deny any ! ! ! gatekeeper shutdown ! ! line con 0 line aux 0 line vty 0 4 access-class 4 in password 7 xxxxxxxxxxxxxxx login ! end
any suggestion will be apprciated..
ram
"hari" schrieb im Newsbeitrag news: snipped-for-privacy@posting.google.com...
On each Interface is this line: | no ip route-cache cef
In this case, each routing decision goes over the CPU, maybe it´s better you enable cef and route-cache on the fa interfaces.
Please look at "show version". Is there a line like "mb(x) has xxx bandwidth points"?
Regards
Carsten Remien
I'd check for duplex mis-matches. Do you see errors on your fast-ethernet interfaces on the router? How is your NIC set on your laptop? If the router is set for full-duplex and the laptop is set to auto, then the laptop will drop down to half-duplex -- giving you a duplex mis-match.
