Hello.
I have a problem with counters on vlan and fastethernet interfaces. They very often display inexact values.
Test network draft below.
Network has three Cisco 1812 V03 routers. At laboratory i use IOS:
Cisco IOS Software, C181X Software (C181X-ADVENTERPRISEK9-M), Version
12.4(6)T2, RELEASE SOFTWARE (fc1)
Test network scheme.
R1 R2 R3 FE0 192.168.5.1 192.168.5.2 - FE1 - 192.168.6.2 192.168.6.1 TUN10 192.168.10.1 - 192.168.10.2 VLAN100 192.168.100.1 - 192.168.200.1
Error description
When the network load is low, information about 5 minute input/output rate on interfaces are strange.
After high transfer between host, and after stop transmission, I see information like this below.
R3#sh interfaces vlan 100
Vlan100 is up, line protocol is up
Hardware is EtherSVI, address is 001b.5352.b702 (bia 001b.5352.b702)
Internet address is 192.168.200.1/24
MTU 1500 bytes, BW 100000 Kbit, DLY 100 usec,
reliability 255/255, txload 1/255, rxload 1/255
Encapsulation ARPA, loopback not set
ARP type: ARPA, ARP Timeout 04:00:00
Last input 00:00:15, output never, output hang never
Last clearing of "show interface" counters never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 2
Queueing strategy: fifo
Output queue: 0/40 (size/max)
5 minute input rate 68000 bits/sec, 0 packets/sec
5 minute output rate 0 bits/sec, 0 packets/sec
146885 packets input, 81350484 bytes, 0 no buffer
Received 114 broadcasts, 0 runts, 0 giants, 0 throttles
0 input errors, 0 CRC, 0 frame, 0 overrun, 0 ignored
146792 packets output, 6790236 bytes, 0 underruns
0 output errors, 1 interface resets
0 output buffer failures, 0 output buffers swapped out
R3#sh interfaces fastEthernet 1
FastEthernet1 is up, line protocol is up
Hardware is PQ3_TSEC, address is 001b.5352.b703 (bia 001b.5352.b703)
Internet address is 192.168.6.1/24
Keepalive set (10 sec)
Full-duplex, 100Mb/s, 100BaseTX/FX
Last input 00:00:04, output 00:00:00, output hang never
Input queue: 0/75/0/0 (size/max/drops/flushes); Total output drops: 0
5 minute input rate 0 bits/sec, 0 packets/sec
5 minute output rate 56000 bits/sec, 0 packets/sec
175413 packets input, 18108992 bytes
Received 19143 broadcasts, 0 runts, 0 giants, 0 throttles
0 watchdog
0 input packets with dribble condition detected
184109 packets output, 93094988 bytes, 0 underruns
0 output errors, 0 collisions, 3 interface resets
After low transfer between hosts, like ping between host I see information like this below.
R3#sh int vlan 100
Last input 00:00:10, output never, output hang never
5 minute input rate 0 bits/sec, 1 packets/sec
5 minute output rate 0 bits/sec, 1 packets/sec
147027 packets input, 81367271 bytes, 0 no buffer
Received 209 broadcasts, 0 runts, 0 giants, 0 throttles
146851 packets output, 6795538 bytes, 0 underruns
R1#sh int vlan 100
Hardware is EtherSVI, address is 001b.5352.b672 (bia 001b.5352.b672)
Internet address is 192.168.100.1/24
Last input 00:01:10, output never, output hang never
Last clearing of "show interface" counters 04:14:02
963 packets input, 94935 bytes, 0 no buffer
Received 129 broadcasts, 0 runts, 0 giants, 0 throttles
856 packets output, 61446 bytes, 0 underruns
0 output errors, 0 interface resets
Configuration of test routers
version 12.4
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname R1
boot-start-marker
boot-end-marker
enable secret 5 $1$dpdo$q6V4fLGEHI58Av2sOVhGl1
no aaa new-model
resource policy
ip cef
no ip dhcp use vrf connected
ip dhcp pool CIBOR
network 192.168.100.0 255.255.255.0
default-router 192.168.100.1
interface Tunnel10
ip address 192.168.10.1 255.255.255.0
tunnel source FastEthernet0
tunnel destination 192.168.6.1
interface FastEthernet0
ip address 192.168.5.1 255.255.255.0
duplex auto
speed auto
interface FastEthernet1
no ip address
shutdown
duplex auto
speed auto
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface FastEthernet2
switchport access vlan 100
interface FastEthernet3
interface FastEthernet4
interface FastEthernet5
interface FastEthernet6
interface FastEthernet7
interface FastEthernet8
interface FastEthernet9
interface Vlan1
no ip address
interface Vlan100
ip address 192.168.100.1 255.255.255.0
router eigrp 100
passive-interface Vlan100
network 192.168.5.0
network 192.168.10.0
auto-summary
ip route 192.168.200.0 255.255.255.0 192.168.10.2
no ip http server
no ip http secure-server
control-plane
banner motd _ *** R1 *** _
line con 0
line aux 0
line vty 0 5
password qaz123
login
webvpn context Default_context
ssl authenticate verify all
no inservice
end
version 12.4
hostname R2
boot-start-marker
boot-end-marker
enable secret 5 $1$oHFJ$dvCocwbHro.cfW8wGo/g7/
no aaa new-model
resource policy
ip cef
ip address 192.168.5.2 255.255.255.0
duplex auto
speed auto
ip address 192.168.6.2 255.255.255.0
duplex auto
speed auto
interface BRI0
no ip address
encapsulation hdlc
shutdown
switchport access vlan 50
interface Vlan1
no ip address
interface Vlan100
no ip address
router eigrp 100
network 192.168.5.0
network 192.168.6.0
auto-summary
no ip http server
control-plane
banner motd _ *** R2 *** _
line con 0
line aux 0
line vty 0 5
password qaz123
login
no inservice
end
version 12.4
hostname R3
boot-start-marker
boot-end-marker
enable secret 5 $1$Y4Jx$gB716CqmQreeUzWMbYXfI1
enable password line
no aaa new-model
resource policy
ip cef
ip dhcp pool CIBOR
network 192.168.200.0 255.255.255.0
default-router 192.168.200.1
interface Tunnel10
ip address 192.168.10.2 255.255.255.0
tunnel source FastEthernet1
tunnel destination 192.168.5.1
no ip address
shutdown
duplex auto
speed auto
ip address 192.168.6.1 255.255.255.0
duplex auto
speed auto
interface BRI0
no ip address
encapsulation hdlc
shutdown
interface Vlan1
no ip address
interface Vlan100
ip address 192.168.200.1 255.255.255.0
router eigrp 100
network 192.168.6.0
auto-summary
ip route 192.168.100.0 255.255.255.0 192.168.10.1
no ip http server
control-plane
banner motd _ *** R3 *** _
line con 0
line aux 0
line vty 0 5
password qaz123
login
no inservice
end
Please help me to solve my problem
Regards
Przemek Ciborowski.
