Basic Config help needed 1841 Router 2 ethernet
Feb 15, 2007 2 Replies
Hi, I am attempting to configure an 1841 with 2 Ethernet connections and am unable to get things working with a simple config.
My setup is :
External IP Ethernet 0 - Internal IP Ethernet 1 NAT 10.0.0.X/24
Below is the config can someone notice any mistakes?.
I'm trying to replace an Belkin router with the 1841
Any help would be appreciated
thanks.
version 12.4
service timestamps debug datetime msec
service timestamps log datetime msec
no service password-encryption
hostname 1841-Energy_centre
boot-start-marker
boot-end-marker
enable secret 5 $1$mDzN$iWCpz4fKcx5PIOf6pwgBs0
enable password 123tcp45
no aaa new-model
ip cef
interface FastEthernet0/0
ip address 62.49.X.X 255.255.255.240
ip nat outside
ip virtual-reassembly
duplex auto
speed auto
interface FastEthernet0/1
ip address 10.0.0.254 255.255.255.0
ip nat inside
speed auto
full-duplex
no mop enabled
ip route 0.0.0.0 0.0.0.0 62.49.X.X
no ip http server
no ip http secure-server
ip nat inside source list 15 interface FastEthernet0/0 overload
access-list 15 permit 10.0.0.0 0.0.0.255
control-plane
line con 0
line aux 0
line vty 0 4
password XXXXX
login
scheduler allocate 20000 1000
end
Config is fine, no problems with it.
What type of device is the outside interface patching in to? If a cable modem you would need to power it off for about 2 minutes to clear it's MAC table, most only allow a single MAC and the Belkins may be cached in there.
What does a show interface say? Are they both up and up?
From the router itself can you ping your default gateway?
Hi thanks for the reply.
Its and ADSL modem so at the mo there is an ADSL modem device with external IP address- Ethernet - Belikin ethernet router with external IP (this works fine)
yes both interfaces were up and up, couldnt ping default gateway.
