pppoe server configuration help in cisco 2801
Jul 18, 2005 1 Replies
Hi All,
I am running IOS 12.39(11)T in my cisco 2801 router. I'm not getting response for the PADI packets received by 2801. Under the vpdn-group, accept dialin, protocols i dont see pppoe. It shows only pptp,l2tp..So i specified the protocol as 'any'. When i enable the pppoe debug logs, it is showing that the PADI packets are being received but not PADO being sent out..Do i need to change the IOS to support pppoe server
Attached is my running config
! version 12.3 service timestamps debug datetime msec service timestamps log datetime msec no service password-encryption ! hostname sngdemo !
username cisco privilege 15 secret 5 $1$pvH8$PBwgTSwLcoguIW.m45JxJ0 mmi polling-interval 60 no mmi auto-configure no mmi pvc mmi snmp-timeout 180 no aaa new-model ip subnet-zero ip cef ! ! ! ! ip domain name yourdomain.com virtual-profile virtual-template 1 vpdn enable ! vpdn-group 1 ! Default L2TP VPDN group ! Default PPTP VPDN group accept-dialin protocol any virtual-template 1 local name miniv ! vpdn-group 2 ! no ftp-server write-enable ! ! ! ! interface FastEthernet0/0 description $ETH-LAN$$ETH-SW-LAUNCH$$INTF-INFO-FE 0$ ip address 192.167.10.1 255.255.255.0 speed auto full-duplex pppoe enable no cdp enable no mop enabled ! interface FastEthernet0/1 no ip address shutdown speed auto full-duplex no cdp enable no mop enabled ! interface Serial0/1/0 no ip address shutdown clockrate 2000000 ! interface Virtual-Template1 mtu 500 ip unnumbered FastEthernet0/0 peer default ip address pool pppoe-pool ppp authentication chap callin miniv ppp chap hostname miniv ppp chap password 0 test ! interface Dialer1 ip address negotiated ip mtu 500 shutdown dialer pool 1 dialer-group 1 fair-queue ! ip local pool pppoe-pool 192.167.10.10 192.167.10.100 ip classless ! ip http server ip http authentication local ! snmp-server community public RO no cdp run ! !
