2924-XL Port Aggregation (port-channel)
Oct 17, 2007 3 Replies
Jump to replies (3)
Does anyone know if the 2924-XL supports port aggregation, I want to bundle 2 ports together to give a faster uplink to the rest of the network.
I have tried the commands:
conf t
> interface port-channel 1
which if you type "interface ?" lists port-channel as an option - but it borks and complains at the command with the caret pointing to the "p" in port-channel.
Any help would be greatly appreciated.
Thanks
Steve
I don't have any 2924s, and couldn't find any explicit documentation on Cisco one way or another. I would presume if you have the command in your IOS, that you are good, but the error is a strange one. What version of code are you running? Hopefully a bug or something, but I'll continue looking at the 2924 documentation in the meantime.
see Catalyst 2900 XL and Catalyst 3500 XL Software Configuration Guide, Release 12.0(5.x)WC1
It appears that on the 2924 XL FastEthernet port aggregtion is ocnfigured wihtout using the interface port-chanel syntax
config t interface port group 1 distribution destination
interface port group 1 distribution destination end
Thanks :) that seems to have worked for the 2924XL - now for the sparkly new 1801 router - don't suppose you have any idea for that? its running IOS 12.4(15)
Ste
